power
Discussion in '1982-Present GM Diesel' started by 6_2liter, May 12, 2001.
  1. 6_2liter
    6_2liter Registered Member
    May 12, 2001
    8
    i was wondering if there were a few simple ways to add some power to my stock 6.2 liter.......any hints????? maybe try-y headers or something??????
  2. chevy4x4
    chevy4x4 1/2 ton status
    Apr 27, 2000
    1,454
    look around or do a search in this forum...I've posted the same question. Also, check out <A target="_blank" HREF=http://thedieselpage.com>http://thedieselpage.com</A>
  3. Oblin Goblin
    Oblin Goblin 1/2 ton status
    Apr 30, 2000
    205
    Davis, CA
    Headers would help but not as much as on a gas engine 'cause the 6.2 redlines at 3600 rpm. For a little more money than just headers you could leave the manifolds and get a high flow exaust that'll give you 20 - 30 more horse power. Banks - www.getpower.com - probly has the best high flow intake and exaust. Of course the best mod you can make is a turbocharger if your up for that. Banks has about the only kit worth considering for the 6.2.
  4. NewK5Guy
    NewK5Guy 1/2 ton status
    Mar 2, 2001
    556
    Alexandria, VA
    A good high flow dual exhaust with a crossover pipe is the agreed upon best way to go. Worth pleny of power. The aforementioned Banks exhaust is supposed to be pretty good, too. Since the diesel operates at suck low rpm's, a good high flow exhaust is crucial. Actually, headers are a good idea, but I don't know of anybody that makes them for the 6.2. A snorkel and remote mounted airfilter will help with some low end power, but you're on your own there. You'll have to fab up something home grown. I don't know of anybody that makes a cold air setup for the n/a 6.2. Still looking.
  5. 6_2liter
    May 12, 2001
    8
    thanks for the hints guys. ill check out bank's options, and look on the diesel page.
    jesse
  6. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Idea for ya...
    On the DieselPage back in 1997...I haven't seen this myself....but its works well...DUAL air filters. You need to build a new air cleaner or fabricate something to close the holes up. Just stack another air filter on top of the other. And second...kill the stock air tubes from the outside. Kill the muffler thats there too!!
    http://SK-15.coloradok5.com
    Roads? Where we're going, we don't need any roads!
  7. childs
    childs Registered Member
    Mar 15, 2001
    19
    delaware usa
    The diesel wants lots of air but also cold air where the molecules are smaller so you can fit more of them in the cylinder at one time. Instead of eliminating the fresh air intake or two filters, add another fresh air intake to the other side of the filter box.
    DE k5
