Power
Discussion in '1982-Present GM Diesel' started by Tybee, Oct 16, 2001.
  1. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    Just wondering if anyone else has the same experiences with there diesel. Sometimes I notice a big difference in power the engine has from day to day, some times it lags other times it doesnt and I dont know why. Any ideas for why it does this?
    1984 GMC Jimmy 379 diesel, 700R4, 3.73s, 31x10.50 x 15
  2. Danno
    Danno 1/2 ton status
    Aug 4, 2001
    487
    Rockford, IL
    Mine's started doing this now that I'm plugging vaccuum leaks. I think it's due to the EGR engaging all the way.
    My theory (at least for my truck) is that when the EGR is kicking in 100%, my engine isn't getting enough fresh air, and I lose power. When the EGR isn't working (vaccuum leak suckin air), it stays closed, and I get nothing but fresh air.
    I wonder if there's a difference in the size of EGRs for low and high altitude engines?
    1984 K5 Blazer 4x4 Silverado
    6.2L diesel, 700R4, 3.42 gears, 31x10.5" tires
  3. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    I guess ill lookat it this weekend, and I would think all the altitude differences are with the fuel pump but you never know.
  4. Oblin Goblin
    Oblin Goblin 1/2 ton status
    Apr 30, 2000
    205
    Davis, CA
    I've noticed this too. I think its maily differences in atmosphereic conditions. Diesels are more sensitive to temperature and pressure than gas engines. Cool high pressure days are the best for power. Also I think it depends on how you run the engine. I've noticed if I've been drving around town alot my perfomance suffers some. I need to run it on the freeway for a couple of hours or go pull some hills to "clear things out." I think if you don't clear it out once in a while you get soot deposits on the injectors which can hurt perfomace.
