power
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JayG, May 31, 2000.
  1. JayG
    JayG Registered Member
    May 23, 2000
    8
    erie, pa
    How can I get more power out of my 305 engine??
  2. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Rebuild it ? Add a Supercharger, or Turbocharger ?
    Advance the timming, run some High Octane fuel, and a good shot of NOS ?
  3. Bigd
    Bigd 1/2 ton status
    Apr 3, 2000
    399
    Co,Colorado Springs
    Blow it up.This will give you excuse too build a different motor.Just kidding.Couldn't help my self.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    305's will respond to the same performance goodies that liven up a 350. Headers, intakes, cams, exhaust, etc. The same parts on a 350 will make more power than on a 305, but they will perk up a 305. Replacing the 305 with a bigger engine to begin with works fine also!
    HarryH3 - '75 K5
  5. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Mine was getting sluggish and I just did a simple tune-up on it and that juiced it up!
    YEEE HAAWWW[​IMG]
  6. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Man. It depends on how much more power you need. Why don't you do a cat-back exhaust, K&N air filter, and an ignition upgrade. And save the rest of your money to build a 350 if thats not enough. You can get much more power with a 350.
    '73 K5
    Chevy good...Ford bad
  7. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    what exactly consistes of a cat back exhuast...
    Bryan
  8. loudnowlouder
    loudnowlouder 1/2 ton status
    Jan 29, 2001
    539
    Ellicott City, MD
    well if you dont have to have your emissions checked you can pull the smog pump..
    i know when i got mine the a/c needed recharged, i decided against it, so i pulled the a/c belt, and then pulled the smog belt while i was at it, its quite surprising how much power you take back and put to the wheels...
    that was my first and only upgrade before my engine locked up...
    i do believe someones signature on this site is "never rebuild a 305", and i completely agree, save your cash for a 350 or bigger...
  9. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    new pipe, muffler, and on some systems, tips, that installs after the cat.
  10. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    I've been researching this lately. I actually plan on rebuilding my old 305 and putting it in place of my 350. Then I'll rebuild my 350 and put it back in place of the 305. It's a good thing motor swaps only take 6 or 7 hours.
    Anyway here's what I'd do and the order I'd do them. #5 has two parts because you can choose one or another.
    1. Tune your carburetor. Get some DR rods for the secondaries.
    2. Edelbrock 2101 intake. Good for ten horses or so unless you've got a crappy equalized dual plane intake then it's worth more.
    3. Headers. Good for just about ten horses. Find 1.5" primaries if you can because otherwise you'll sacrifice some low end torque.
    4. 2" open spacer under the carburetor. This slowly generates horsepower but it doesn't break the 5hp mark until 3500 rpm. If you've got room, stick it in there. It's only $20. Worst case scenario is that you'll lose some bottom end torque and you'll have a $20 piece of phenolic plastic that would go great on that 400SBC powered Camaro you've been dreaming about.
    5a. Find some 58cc heads if you don't already have them (I've never heard of them being in a truck or blazer). Get them machined for 1.94 intake valves instead of stock 1.84. This should bring your compression ratio up above 8:1. If you can, find a set that you can mill some material off so you can get the compression up a little higher yet.
    5b. Camshaft. It seems that 108° works the best. I don't know anything more than that--I'm still researching.
    6. Rebuild. Stick some higher compression pistons in it. Port the heads.
    After both #5s and a rebuild you're supposed to be able to squeak 250hp@5,000rpm with a properly tuned carburetor.
    Most 305s had between 7.5:1 and 8.0:1 compression ratios. If you take that up to 9.5:1 you'll see around a 5% horsepower increase. You figure 2-3% per point of compression increase.
  11. dyeager535
    26,980
    All truck 305's are 9.2:1 stock AFAIK, and the HO car ones (SS) were as well.
  12. Jay73K20
    Jay73K20 Registered Member
    Mar 4, 2002
    67
    First give your motor a compression test, if they are with in ten percent of each other go with the mods. Best bag for the dollar, Dynomax ceramic coated 1.5 3/4 length headers WLK-86118 219.95 (I love them on my truck), Custom 2 1/4 y pipe that dumps into a single three inch exhaust with a 70 series muffler, summit cam&lifters SUM-K1102 $71.95, Edelbrock EPS manifold EDL-2701 129.95, Edelbrock EPS carburetor EDL-1406 244.95. 86' carbs are all right as long as they're fully functional, do you know if both soleniods work. Edelbrock is just two easy to work with. I run a Q-jet built by Jet Performance hopping for better MPG and it runs good and same MPG but I had better throttle response with my EDL. Then again the Q-jet is easier to start.
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    According to DD 2000, my 260 HP 305 would make more torque as a 350, but no additional power without a bigger cam and better cylinder heads.
  14. amm888
    amm888 1/2 ton status
    Jul 20, 2002
    309
    Woodland Hills, CA
    loudnowlouder - what do you mean by "pulled the a/c belt"? i've got a bum a/c compressor, can i just pull it out and add some power?
