powersteering shaft broke and pully stuck, need help! *pics*
Discussion in 'The Garage' started by BranndonC, Jan 7, 2004.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    ok so i pulled my p/s pump and realized the reason it went bad was the shaft from the pully broke. well any way, long story short, we cant seperate the pully from the shaft... any suggestions?????? please!
    [​IMG] /forums/images/graemlins/ignore.gif
    as you can see i broke a punch mis-using it, now its jammed in there. /forums/images/graemlins/rolleyes.gif
  2. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    /forums/images/graemlins/angryfire.gif BREAK OUT THE TORCHES! /forums/images/graemlins/angryfire.gif
  3. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I would probably just go to the wrecking yard and get a whole new pump and pully. That is probably your best bet. /forums/images/graemlins/thinking.gif
  4. frankin5
    frankin5 Super Mall Crawler
    Oct 15, 2002
    882
    114
    chico,calif
    take it to a machine shop and have them press it out.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Why not just rent the pulley puller? Can you get what's left of that punch out?
    If not, grind it off flush or close to flush and use a power steering pulley puller, available at your local auto parts store, to get it out.
  6. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    A normal pulley puller will pop it right off...
  7. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    nope i've used the pully puller, i own one, if you look at the 2nd pic, you can see how it ripped the outter lip from the center piece
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I see the missing lip now. Nevermind what I said then. Go to the parts store and buy a new pulley.
  9. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Yeah, or the wrecking yard and get a whole new pump and pulley if you don't mind having an used one.
  10. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    heat give some heat man!!! if you want to save it that is. even a new one cant be that much.
  11. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    It looks like you tried to use a two-jaw puller instead of a power steering pulley remover. The correct puller pulls on the entire circumference of the lip, not just in a couple of spots. /forums/images/graemlins/blush.gif If you can rent or borrow the correct puller you might still be able to get the pulley off.
  12. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Hmm, the third pic just loaded for me. It looks like the pulley is bent. /forums/images/graemlins/eek.gif If so, just toss it and find another one. If it doesn't toss/trash belts, the vibration is likely to kill the new pump. /forums/images/graemlins/frown.gif
  13. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i dont see how the correct puller could do that to the pulley, time for junkyard visit now.
    godo luck
  14. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Yeah looks like a 2 jaw puller was used... Either way, time for a new one.
  15. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    buy a NEW pulley..
  16. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    Happy Bday Confedneck
  17. Confedneck
    Nov 1, 2002
    5,236
  18. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    A new pulley is like $20 and a lifetime warranty pump $50 and a lifetime warranty hose another $20. Too cheap for junkyard parts IMO. If you want to do that to your truck, that's fine, they'd probably get 20-30 for a pump at the yard though.
