Powertrax Locker
Discussion in 'The Garage' started by 1985K20, Jan 13, 2005.
  1. 1985K20
    1985K20 1/2 ton status
    Jan 11, 2005
    191
    Quebec,Canada
    just wandering is a powertrax lock-right locker a good investment for a 14 bolt rear end:confused:
  2. reeser
    reeser 1/2 ton status
    Oct 8, 2001
    434
    Hayden Lake, ID
    investment to me means lasting over the long run. in this case i would say no because the full detroits are so cheap for the 14 bolts, provided it is a full floater. buy a detroit and never worry about your rear end again, they're tried and true for more than 40 years. 350 for a new one, i paid 200 for a used one. either way, you can't go wrong w/ a detroit. don't buy the lok rite based on 'investment'. if you were asking based on budget there might be room for discussion. investment there is no question, buy a detroit:D
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Altho i have lockrites and like them i have to agree with Reeser. Lockrites are a good budget upgrade but they are not near as strong as a detroit locker. I think lockrites are one of the best upgrades to do to a 10 bolt. But if I were to "invest" in a 14 bolt I would put in a Detroit.
  4. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    how exactly are lock-rights and detroits different for the 14 bolt?
    they are both "lunch box" lockers in this application.
    :ears:
  5. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    :what: :what: What???? Detroit Lockers are not lunchbox lockers. The are a full locker that replaces the whole carrier assembly. In stead of replacing the spyder gears like a Lockrite and other lunchbox lockers do. Detroits are way stronger..Detroit lockers are about the strongest lockers made.
    The only thing you can be thinking of is the Detroit EZ lock which is a lunchbox locker. But as far as I know they dont make them for 14 bolts. They only make then for the mighty 10 and 12 bolt diffs. They also break easily.
  6. chevydan3
    chevydan3 1/2 ton status
    Nov 27, 2004
    409
    Reno, Nevada
    All real lockers, Lock-Rites and Detroits included, use the stock carrier in a 14ff. So they are "lunchbox lockers" in this application. Replace the spider and side gears only.
  7. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    Powertrax
    I run a Powertrax No-Slip in my rear 10-bolt and I've been happy with it. A full detroit would have been nice, but the No-slip costs $250 less and I only run 33's. I been beating the snot out of it for 2 years and haven't broke it yet.
    The No-Slip is also stronger than the origional Lock-Rite and the Detroit EZ locker.
    The No-Slip is also much smoother on the pavenment than most other lockers if you need to run your truck as a DD.
  8. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    OOps yur right! I forgot Detroits use the stock carrier in 14 bolt FFs. I guess I was thinking about C clip axles. I still have a hard time thinking of a Detroit Locker as a lunchbox locker tho. Because they are cheap for 14FF, I still would pick a Detroit over a Lockritre.
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Agreed.
  10. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    but doesn't the lockrite act better on the tar? kinda like ackrite? :haha:
  11. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    I have heard less complaints about the detroit (actually very few) vs. the lock-rite, but that is because the complaints I heard were from people using them in 10 and 12 bolt axles. Both seem to have the same characteristics as far as locking, unlocking, and driveline slack. I have driven with both and don't notice much difference. I decided to go with the Lock-rite in my 14FF because of funding when I did it (was hoping for the detroit but couldn't afford the price back then). I have been pounding it with a heavy right foot, towing, and truck pulling and there have been NO complaints.***
    Note***: I am only running 35" tires max right now, so that may be a factor on why it hasn't broke.
  12. 1985K20
    Jan 11, 2005
    191
    Quebec,Canada
    thanx for your comments, i appreciate. 1985K20.:)
