powertrax lockright
Discussion in 'The Garage' started by johnathan, Feb 16, 2006.
  1. johnathan
    johnathan 1/2 ton status
    Sep 26, 2005
    376
    Ocean Springs,MS
    I'm about to regear the front,and I'm on a tight budget.How do yall feel about the lockright for the front?Don't wanna weld it.
  2. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Get an Aussie Locker instead. Use Machinewave in the Vendor forum over on Pirate and you will get a better deal.
  3. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    I have a lock right in my rear and I am not very pleased with it. I noticed that after I installed it I kept getting incressed play in the rear end. So I took apart the axel and all the play is in the locker. So called them up all huffy puffy, and they said that it is supposed to have up to 27 degrees of play in it before it will engage the axel shafts. And having a stick it is noticable when you get on and off the gas and when you first start from a dead stop. Its not that bad but just annoying. Also I'm sure thats not that good for the axels.
  4. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    i have a LocRite in the front of the Burb, i tried the welded thing for a bit, but seriously hated it, I won't remove my LocRite, unless of course i get a free air locker,,,which we know THAT won't happen.
    Just make sure you have manual lockouts on the hubs, makes it easier to use.
  5. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Got one in the front in my D60. 40" tires, 454 and I use it. I have blown two ring and pinions, some hubs, drivelines, and axle shafts. That same Lockrite is still there. Spent $260 bucks at the time 5 years ago.
    But I have heard people breaking them. I have also heard Detroits letting go. Just depends I guess.
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Got one in my rear . I drive it daily , and actually wheel it . No problems :thumb:
  7. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    had them front and rear. If your on a budget like I was with 1/2 ton ****, Id get them. No problems what so ever and I had them in my Daily Driver for 2 years, even did the tank trap in hollister with them no breakage but increased wear on the center pins over time. If you get them, I recommend getting hardened center pins from Randys ring and pinion (like 15$ each). Must have unlockable hubs on for turning ability. If your not on a budget get full lockers, there stronger.
  8. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I've had one in my front D60 for several years running 38" tires. It has survived two broken 30-spline stubshafts and a broken necked-down inner shaft with no problems. I also don't notice it on the street at all when in 2wd and I run front drive flanges.
    78Buford on here stripped a Lock-right out.....worked in forward but no reverse.....but that was with 42" tires, big block, and a 7,000 lb. truck and it lasted several years.
  9. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I run a lockright in my 10 bolt front. It has done me just fine. I ran it hard for 2 years with 35's in the rocks of AZ. I like it and have had friends that have had them do very well for them too.
    Harley
  10. CB77GMC
    CB77GMC 1/2 ton status GMOTM Winner
    May 6, 2005
    771
    Heath Springs, SC
    Running Lockrights front 10b w/lockouts and rear 12b on/off road no problems going on one year now.
  11. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    '85 Burp, corp 10bs, 32", 3:42, Warn hubs, TH350, LockRite in the front and NoSlip in the rear, DD, never a problem and it crawls like a spider.:D
  12. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
    lockrite it is :D THANKS!!!!!!!!
  13. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    just buy it new. I bought mine used for 250 shipped but the parts I have boughten to get it to work is about 350 and it still didnt work. so now Iam back to an open diff. Many others have had good luck with them, my burb is always diffcult
  14. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Juat an FYI, but Summit has the Lock-right for $229 (after a $61 instant rebate) right now. I'm "this close" to ordering one for the rear (both axles currrently open), for both axles, or maybe just the front.
    I'm more of a lifelong gearhead than a wheeler here in this flat country. I had a Detriot on my '69 Mach I (sold the car 22 years ago, unfortunately), and really liked that unit, but I'm not sure if I'd be better of with Powertrax's No-Slip or their Lock-right in a DD Blazer, if the purpose is mainly to get a better grip on the street during WOT acceleration.
    (Perhaps I should buy a Lock-right for the front, at that fire-sale price?)
