Powertrax no-slip
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MA87K5, Oct 20, 2002.
  1. MA87K5
    MA87K5 1/2 ton status
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    I'll be putting a powertrax no slip in the front diff. (Got it for a real good price in new condition.) The question I have is which one is better between the powertrax no slip and the detroit ez locker. I plan on putting the detroit ez locker in the rear. I know that posi front and rear will give me outstanding traction offroad in 4 wheel and very good 2 wheel traction on road. I don't have a worry with my rear tires breaking loose because I know how my truck acts and what it can do, I try not to go beyond that.
  2. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    EZ-locker is junk. Buy a Powertrax Lock-Right. It's the same price and a lot stronger. I'm planning on getting one.
    Do a search and you'll see what I mean.
  3. MA87K5
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    I would but the lock right is not recommended for a daily driver. The no slip is $430, And the ez locker is $250. I was told that the ez can handle up to 1100 HP. Why is the ez locker junk? Thanks
  4. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    Not reccomended for a Daily Driver, unless you keep the front hubs locked and the transfer case in 4wd, or you have a full time 4wd setup, the lock right will do just fine. Keith and I both had Lockrights in our fronts for 3 or 4 years with NO problems and we both drove them every day. Keith had a lock right in his rear as well. At 450 for the No slip, your getting within 50 bucks of a full Detroit locker.
    Depdog
  5. Grim-Reaper
    7,385
    Atlanta
    You were lied too. EVERY EZ I have ever seen installed in the rear has blown PERIOD. One of them was on BigJbears 80 with a VERY tired engine. Robzilla lunched two and the second one he blew within a mile after he installed. His truck has a stock 350 crate that I'm sure is about 800hp short of 1100.
    The EZ paper work clearly states do not use with over 32 inch tires. Hmmmmmm can't handle 33's and a stock engine and you expect it to handle 1100hp?
    Save your money. Lockright or a power track is a much better product. Personnaly I would not install a lunch box locker in the rear of anything. Go with a full Detroit if you want a locker. I can guarantee less potential for problems. Those lunch box lockers put a lot of stress on the carrier and can break them.
    ALL full lockers come with that "not for daily driver" because they adversley effect the handling on the street and in particular they can be a real handfull on ice. The manufactures are just protecting themselves from lawsuits because some idiot didn't adjust their driving style and totals their truck.
  6. wrathORC
    Apr 27, 2002
    908
    Hancock, MI
    The Detroit E-Z Locker breaks. The only thing it's ever been recommended for around here is the front axle of a Jeep. And a kid broke his with a 2.5L on 31x10.50s. There are a couple guys that have the old style E-Z Locker that swear by them. But these are also at least five years old from what I've been told (these guys are in their late twenties and are working on their doctorates so they've been in the club for a while).
    You can get a Lock-Right for $240 for a ten bolt. It's on my wishlist for my front ten bolt.
    http://nationaldrivetrain.com/shopsite_sc/store/html/page8.html
    Since you couldn't be bothered to do a simple search, I did. It's proof that the E-Z Locker isn't much, if any, better than a Gov-Lock.
    http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=blazer4x4&amp;Number=494876&amp;Forum=blazer4x4&amp;Words=lock%20right%20locker&amp;Match=And&amp;Searchpage=0&amp;Limit=25&amp;Old=allposts&amp;Main=403037&amp;Search=true#Post494876
  7. MA87K5
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    Ok Ez lockers suck. How about the Eaton posi for the rear? Will I have to worry about the powertrax no-slip if I put it in the front? Thank you for all the info everyone has givin me. I shall stay away from the ez locker.
  8. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    I have had a lock-right in my rear 10 bolt for 6 months now and I have towed a blazer on a 2 axle trailer with it, played in the dunes and also done some regular wheeling(no rocks though) plus this is my daily driver and it is doing fine. When I have a little more money I will put a welded 14Bolt in the rear of my truck , take the lock-right out of the rear 10 bolt and put in the front.
  9. wrathORC
    Apr 27, 2002
    908
    Hancock, MI
    Any clutch-type limited slip will work. Just don't get the cone-type.
    I'd stick the no-slip in the back and put a lock-right in the front. But that's just me.
    My 14FF has a grenade-lock in it and I'll either run that or weld it. I'm no fan of anything but spools, clutch type limted slips, or open differentials in the back. I don't like lockers in the back because they can be unpredictable. I'm sure I'd be alright if I just got used to it.. but anyway.
  10. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    i was thinkin of putin that exact setup with the no slip rear and lock-rite front, anyone had in on 2 10 bolts with 35s?
  11. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    What Grim said. BTW the 350 in an '80 Jimmy was rated @ 160 HP when it was NEW. Add 20 yrs &amp; guess about the power output (I can spin the flex plate by hand, plugs in, no gloves on), so 1100 HP my ass. The EZ worked when I had 31s but only 1 &amp; 1/2 trips w/ 35s. And do a search!
  12. MA87K5
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    The 1100hp was what someone told me that the ez locker could handle not the what the engine has. Does anyone have or is familiar with the Eaton posi unit durability? Thanks
  13. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Exactly, I was saying the EZ couldn't hold up to the power my '80 put out so there is no way it would last behind a motor that made 1100HP. Sorry for the confusion.
  14. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i had one in my 12bolt with 33's an old tired 350 and a sm465 and was wheeling in the sand and blew mine apart put 8 holes through the diff cover /forums/images/graemlins/shocked.gif
  15. MA87K5
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    Well I blew the powertrax no slip the second time I locked the hubs. I didn't even drive on dry pavement. Just snow. Oh well back to the open diff. I thought that the powertrax was a good replacement for the spider and shaft gears but if I broke them without hard wheeling than they must not be very good. I'm glad I didn't pay alot for it. Time for a eaton up front also. Still have no probs with the eaton out back. I'm afraid to look in the carrier for the powertrax to see how bad it is. Maybe this weekend.
  16. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I'v been running a power trax lock rite in the rear for a few years now with no problems. It is a fairly strong unit. My K5 is a dayly driver,tow rig and I wheel it hard. Mud, Rocks Sand and Snow no problem.
    The one thing i have found with them on the ones I have used and helped buddys install is. You should use new thrust washers when you install them. Also if the pinion pin is even a little bit worn replace it also. (The instructions recomend this but most people ignore it.)
    A lot of perple just throw them in an old loose worn out 10 bolt, And blame the locker when they blow . The lockrites were designed to work in close tolerances. An old loose rear end will blow them in a hurry.
    Also they work better and quiter with high quality 90- 140 wt gear oil.
  17. twenty_below0
    twenty_below0 1/2 ton status
    May 16, 2001
    436
    Haines, Alaska ...u.s.
    If you want a TRUE LOCKER with STRENGTH in the rear go with a Spool or a Detroit, Then use the Posi or LOCK-RIGHT in the front this will give you the best dependable traction all the way around! End of Story! just my little opinion /forums/images/graemlins/rotfl.gif
  18. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    A spool is not the same as a locker. "Locker" doesn't just mean that the axleshafts are always locked together. In order to be a locker, it must allow a shaft to disconnect for turning.
  19. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    The powertrax no slip or no spin I can't remember what the name is, isn't the greatest unit out there.
    The powertrax lock rite like the one I use and some here that gave their opinion is different and much stronger. It's cheap, easy to install, and much stronger than the EZ locker made by detroit and basically the same design.
    I agree a detroit locker is better but the lock rite is great for the price and ease of install.
    The no slip I will never even try because of all the bad feedback I got about it.
    Sorry you had to try it /forums/images/graemlins/frown.gif
  20. twenty_below0
    May 16, 2001
    436
    YEAH your right a Spool is not a locker (I should have put Detroit in front of Spool on my other post) that's why I said the best all around traction. For the cash a spool is a great traction additive, much cheaper than a 450.00 Detroit but it's a little harder on the tires. /forums/images/graemlins/eek.gif
