Pre-bent cage
Discussion in 'The Garage' started by SUB-ZERO, Jul 8, 2005.
  1. SUB-ZERO
    SUB-ZERO 1/2 ton status
    Oct 8, 2002
    219
    Virginia Beach,Va.
    Has anyone on here installed a purchased pre-bent cage in a K5?If so which one is best?I have seen on here where people have bought one's from Summit,Jegs,and Smittybuilt but no real feedback.At least not that I'm finding.
  2. ntx78k5
    ntx78k5 1/2 ton status
    Oct 22, 2004
    166
    Home of the Rangers
    To add on to that question, do you tie the cage into the frame or not. On another forum that I read it seems to be split 50/50. Some say if you tie it into an unboxed frame you will crack the frame. ??? :thinking:
  3. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    There are plenty of posts that discuss how to install a cage. There are pros and cons for both methods, I recommend doing a search and reading the other threads.
  4. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    In my opinion unless you are racing at high speeds I would not recommend tying it into the frame. If you are doing some basic off roading I don't feel there is a need to tie it into the frame. Like you said earlier this is split 50/50. Smittybuilt used to make them I wasn't able to find one on their web site. :D
