Prefered engine heads?
Discussion in 'The Garage' started by broncoman6524, Oct 4, 2006.
  1. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    whats everybody runnin/ prefer? i *hope* to build a 383 soon for my senior project adn im unsure as to what direction i should go. ive heard good things about the vortec heads. but im tryin to weigh all my options thanks guys.
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    it really depends on what you are looking to get out of the engine, vortecs can be a cheap option if you are not going to run a huge cam and not to much compression, if you are looking for a big cam and compression you will want to look in to aluminum heads
  3. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    im lookin into the comp cams extreme torque 4x4 series cams. im hoping to have a lower 9:1ish compression so i can try to run 87 or 89 octane
  4. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    the big think with the vortec heads is the max lift is around .500 i belive if you want more than that you will need to spend some money to get the spring pockets machined so you can run a aftermarket spring allowing you to run larger lift cams, for that amount of compression the vortecs should be good for you
