Prep work for painting a top?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Kyle89K5, Sep 26, 2001.
  1. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    Is there any real? I'm just wanting to shoot a quick coat or two on, but I don't want it peeling back of any time soon. Not worried about smoothing it out either, I been running a softop for the last little while and kinda got used to the black, figure I better paint my top.
    Kyle
    89K5
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    If you aren't worried about smoothing it, wipe the hell out of it with reducer or TecClean, scuff it good with a ScotchBrite, and wipe it with one of the above again.
    Special thanks to those lost from IAFF Locals 94 and 854 - You shall never be forgotten
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  3. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    I just smoothed and painted one, and the only thing I really did was prime it. It seemed to soak up a lot of the primer, but I'm thinking that's because I smoothed it.
    Otherwise, pugs idea sounds good.
    Ratch
    <a target="_blank" href=http://k5.8m.com>k5.8m.com</a>
    **Ever stop to think... Then forget to start again?**
  4. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    yup, i just litely sanded the top and wiped it down with aceton and then a tack rag. then i rolled on two coats of some sorta rustoleum pruduct (it's oil based just like the spray but comes in a grey can) anyways it's been two years now and nota chip,crack or peal anywhere.
  5. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Adding something I forgot - don't use lacquer thinner or MEK!! Use acetone or acrylic enamel reducer - lacquer thinner will craze the fiberglass, and MEK will just basically turn it into sticky primordial ooze.
  6. Kyle89K5
    2,273
    OKLAHOMA
    thanks guys. I've gotta get it up to the booth so we can shoot it. I'm getting ready to spray the whole dang truck, just got curious on the top.
    Kyle
    89K5
