Preparing for water crossing
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84k5, Dec 2, 2001.
  1. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    A trail I would like to do involves crossing about 3' or so deep water. My k5 has a 4" lift and 33s. I would like to know what I need to do to keep water out of the inside of the vehicle, and anything else I ought to do/check before going through the water. I'm sure its easier to prevent damage than have to fix it after the fact. TIA
    Brian
  2. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Check the condition of the breather tubes that go to your front and rear diff's and to the t-case. If they are clogged or missing, then water may get into these areas and wreak havoc. Alos measure the distance from the ground to the tip of the breather tube and elevate them if the are under 3'. With a 4" lift and 33" tires, you shouldn't have to worry about water coming into the cab in 3' of water.
  3. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Snorkel, hip waders, and someone with a winch....thanks Todd!!
    Make sure you ain't gonna suck water in if you happen to hit a hole. Make sure your oil, tranny sticks are sealed. The oil fill plug has a cover on it. Make sure yor fan will shut off when it hits water....you don't wanna have to change a radiator in the middle of nowhere do ya? Got everything that might get underwater protected? Think about your center console, CB, CD player, stereo, pop cans.....
    All your breather tubes for the diffs and tranny. Water in them ain't good.
    If you are driving through you don't have much to worry about, but if yer like me and like to make sure I get water everywhere, including inside the engine........
    SK-15
    J**P...it's whats for dinner!
    Roads? Where we're going, we don't need any roads!
    If it wasn't for bad luck I would have no luck at all!!
  4. CV202
    CV202 1/2 ton status
    Nov 14, 2000
    454
    Kingfield, ME
    Use some dielectric grease on your spark plug boot (both ends) and keep a can of wire dryer in the rig. Some people even RTV the dist. cap down and vent the breather off of it. Make sure your intake is shielded enough to deal with some water, the factory snorkel workd pretty good for this. Extend your breather lines (diffs, tranny and tcase) Check your door seals as well.
    Why do people keep calling it a Bronco!!!!! [​IMG]
  5. taterblazer
    taterblazer 1/2 ton status
    Feb 2, 2001
    277
    Boise, ID
    Make sure your airfilter is on tight and if you have an after market one with the filter exposed make sure its water resistant. Saw a guy suck a lot of muddy water through a paper filter like that one time. I like the stock setup on my 88.
