prepping the k5 for a LONG hike!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by lifethroughdeath, Nov 15, 2003.
  1. lifethroughdeath
    lifethroughdeath 1/2 ton status
    Jan 26, 2003
    300
    New Bedford, MA
    Whats up guys, I’m getting ready to say goodbye to the cold barren north I like to call Massachusetts and hello to sunny DaytonaBeach, FL. /forums/images/graemlins/cool.gif 1200 miles later of course, And their enlies the problem. We're packing the blazer as full as we can and hitting the road in mid january. Depending on what vehicle my friend uses i may or may not be towing a small trailer. My question for you is what can i do to make sure the k5 makes it there as smoothly as possible and in one piece. Here's the specs:
    1990 K5 w/ 110,000 original miles, recent full tune-up, stock 700r4 with fresh fluid/filter, headers into H pipe straight into dual glasspacks, K&N offroad air cleaner. 4" lift w/ brand new 33's for the street, 35's for offroad, & recently aligned.
    Also I was thinking of getting an aftermarket tranny cooler. Any tips or things to check/fix would be greatly appreciated. Thanks a lot.
    Nate /forums/images/graemlins/k5.gif
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    a tranny cooler would be nice...a good oil change, use some quality oil, i like castrol, the extended extra quart filter..clean the k&n, re-set tire pressures..make sure the radio and a/c work heh...are you moving to daytona beach for good?? im in fort myers, been here all my 18 years and cant decide if i hate it or like it lol /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Let's see...
    Check/top off diff fluids and t-case fluid.
    Check heater hoses and radiator hoses. Replace 'em anyway if they're more than a few years old.
    Check the belt(s). I like to put new belts on, then toss the old ones in the truck to use as spares. That way you KNOW that they fit. /forums/images/graemlins/cool.gif
  4. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    I always carry on road trips
    1 full size spare tire
    1 extra alternator
    1 complete distrubitor
    1 cap and rotor
    1 ign module
    1 oil filter
    case of oil
    6 qts trans fluid
    1 tube of rtv
    3 qts of gear lube
    4 spark plug wires
    8 plugs
    1 starter.
    4-5 extra belts
    carb rebuild kit
    2 flash lights
    4 way
    complete socket set metric and standard
    bfh
    pry bar
    complete wrench set
    mulit meter.
    but im kinda parinoid.
  5. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ya think!? LOL...but hey..better safe than sorry right!?
  6. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    and yet only 4 spark plug wires?? Why not a whole set /forums/images/graemlins/thinking.gif
  7. lifethroughdeath
    Jan 26, 2003
    300
    New Bedford, MA
    cool, thanks guys i'll check all that stuff too, and my old man was telling me to inflate the tires a little more than normal for mpg reasons...this true?
    and yea i'm moving down there permanentaly, maybe not daytona forever but definately somewhere in florida
    nate /forums/images/graemlins/k5.gif
  8. 99firehawk
    Dec 15, 2002
    491
    "Why not a whole set "
    Well when you replace a set of wires and 4 of them are burned theres not much reason to save the 4 burned ones.
  9. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    camera!!!!!
  10. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    you guys are leaving out the most important things i cant beleive
    so 2 add to the list 4 offical road trip
    1 lots of great music 2 pass the time
    2. 2-3 sheets of 11"x17 " thick paper or a small dry erasable white board to write mesages on for the passing of cute girls to give ya a flash
    3 camera or cam corder accesable at a monents notice in case they do and or god forbid a accident for insurance reasons
    4. a cb tuned into the truckers channel for traffic conditions
    5. a few cans of fix aflat besides your spare tire
    6. & check your ujoint's also or just replace b4 ya leave
    7. check your brakes all around also +
    good full coveradge insurance if your carrier will let ya do it for just 1 month till ya find out whats up
    8 the most important great fun relaxed attitude = great Road trip
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif
    /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
  11. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I do 1000 mile road trips in my 89 K5 all the time. Shoot 1000 miles is just pretty much just a trip to the mall for me.. All I usually carry is my tool box, jumper cables,Oil Trans fluid, water/coolant and a spare Dist module. These are always in my truck anyhow. Course I keep my truck in good shape and always ready to run.
    Yes put a few extra lbs pressure in your tires it makes a difference in fuel MPG.
    On the highway I run my 33"MTs around 30 psi or more depending on load /towing. Basicly what I do is load the truck then and inflate the tires to the point where the truck is squirlly and wants to wander then back off a few psi.
    Get a good 18000 gvw or larger Tranny cooler in ASAP. Espically if you tow get the biggest one you can.
  12. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    I would pack the following for a K5 road trip:
    *small basic tool set
    *spare belt to turn the water pump
    *ignition module
    *full size spare tire
    *2 qts ea of oil & ATF
    *fire extinguisher
    *2 gal drinkable water
    *blanket
    *one spare rear axle shaft
    *jumper cables
    *tow strap, chain, & clevis
    *Haynes manual
    Definitely add the trans cooler. If you have time install a second batt tray and battery. You don't even need to hook it up. If you can swing it make the second batt a deep cycle. Check for loose nuts & bolts. Make sure all maint is current. Don't start w/ a known problem. There are pleny of parts stores along the way. Take the things that will stop you in you tracks.
  13. rebelk5frk
    rebelk5frk 1/2 ton status
    Dec 29, 2001
    815
    Houston, TX
    Check the lugnuts!
    I made a trip from GA to TX and lost a rear wheel while towing another vehicle. Trust me it's pretty scary hitting the median at 75+mph with only 3 wheels. /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif
  14. 99firehawk
    Dec 15, 2002
    491
    "one spare rear axle shaft"
    What are you gonna do with a axle shaft and no jack? or gear lube?
  15. Ben
    Ben Registered Member
    May 3, 2002
    96
    Pick a country in SE ASIA!
    With all the suggestions, you're gonna need to tow a trailor just to carry the parts! I'd say just ship the blazer and take a train!
  16. atlantak-5er
    atlantak-5er 1/2 ton status
    Aug 20, 2003
    225
    Atlanta, GA
    trans cooler and add a trans temp guage. I burnt up my tranny on a long road trip and I didnt even know it was hot!
  17. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    If you leave on a road trip w/o a jack you are not smart enough to change an axle shaft /forums/images/graemlins/rolleyes.gif I guess I needed to tell him to put gas in the tank, too.
    If you don't pour your old gear oil on the ground, you can put it back in. Before you make your next smartass comment saying it can't be done, I've BTDT, it works just fine.
  18. 99firehawk
    Dec 15, 2002
    491
    Make one joke, and people get all defensive???????
  19. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    hey tecton...now THAT animation of ur blazer is more like it!! i dig it!! /forums/images/graemlins/rotfl.gif /forums/images/graemlins/pimp1.gif.. ok..comtinue on folks.. /forums/images/graemlins/rotfl.gif
  20. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    Missed the joke. That's the biggest problem something like this, its had to pick up the scarcasim of a typed word. Next time throw in a /forums/images/graemlins/smirk.gif or if we had it on this BBS :flipoff2: would have been perfect. Or don't, I never used to untill I realized they help in giving those typed words some inflection, like a spoken word. (I still think they are gay, though /forums/images/graemlins/grin.gif)
