Press rod with floating piston?
Discussion in 'The Garage' started by BigBurban350, Jan 27, 2006.
  1. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Will this work?
    Small Block Chevy; Using Press Fit Rods and Floating Pistons?
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    thats what a stock sbc uses from the factory, so yes it'll work
  3. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Almost all SBC engines use press pistons if not all. If you are talking about using a piston that is cut for retaining clips but using a pressed pin that is ok but WHATEVER you do, do not use the clips unless the rods are machined for floating pins or the pins could come out and ruin an engine in minutes.
