Press the clutch and the frame rail moves? uhh is this a bad thing?
Discussion in 'The Garage' started by sled_dog, Aug 31, 2003.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I know k5 frames are twisty and all but my buddy noticed yesterday that when I press my clutch pedal the frame rail pushes away from the motor. Like the frame pushes out at the top where the Z bar mounts and the bottom stays pretty much the same. I got it pretty crossed up last night and never had clutch issues. well except once when I clutched in the middle of a mud hole by accident and dropped it. No damage just a little fun.
  2. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    That really sucks, sounds like a badly cracked frame. Have someone keep pushing the clutch in and out and you get under the truck and try to spot where the frame is moving.
  3. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    I have noticed that the K-5 frames flex/twist way more than I am use to . NEVERENUF had some frame flex and firewall deflection problems when he was running a stick with a C-50 style pressure plate in a K-10 .
    I am trying to help my frame in that area a little bit by adding a pre 1972 2WD style rear engine crossmember - maybe it will help keep the frame from pushing out at the Z-bar connection ?
    Good luck with your problem - I hope your frame is not cracked and it just turns out to be the usual K-5 frame flex/twist.
    Tom
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    if its cracked I'm on the hunt for a pickup or blazer frame and we will have one hell of a crazy daily driven ride, anyone else have an opinion or experience here?
  5. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    i cannot say i have ever seen the frame flex with engagement of the clutch, i have seen the body move though. make sure the body is still attached to the frame.
  6. TJS
    TJS 1/2 ton status
    Nov 13, 2001
    179
    Westport,CT
    If you can fix it then do that. Swapping in a frame takes a long time. I am working on my cracked frame. I have the engine out. I am re-inforcing it though for plowing. Go here and you can see what I have done so far. I have a complete machine and welding shop which makes it easier as well, but you get the idea what needs to be done.
    T.J.
    www.tjsperformance.com
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I wasn't thinking swapping frames with my K5, I'd find another frame and a truck cab and take my trans and motor and everything else would be new.
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It took me three weeks to swap my frame working every night after work last summer.
