Pressing in wheel studs
Discussion in 'The Garage' started by homerman5409, Feb 7, 2004.
  1. homerman5409
    homerman5409 Registered Member
    Dec 12, 2003
    7
    Whats the best way to press in wheel studs into my 72 K5
  2. tRustyK5
    Jul 23, 2000
    36,167
    1,365
    E-town baby!
    I use a BFH...
    Removing em I sacrifice a lug nut, thread it on almost all the way and use the BFH to drive em out. As soon as it's loose I remove the nut and move on to the next one.
    Sometimes a drift of some sort makes it a bit easier to drive them back in. 1" round bar cut about 6-8" long works pretty good.
    Rene
  3. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    I just beat them out with a hammer(no lug nut) and them to put them back on push them in with ur fingers then put a lug nut on and use a impact gun till it drawls it all the way in if your lug nuts are not long enough get some washers and I would recoment getting atleast 1 grade 8 washer to go on the out side becuase sometimes the lug nut will try to go into the washers /forums/images/graemlins/eek.gif
  4. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    with a press?? /forums/images/graemlins/waytogo.gif
  5. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,852
    280
    Truckee, CA
    Somewhere i read you shouldn't pull them in wiht a lug nut when installing. Doing so requires you put a lot more than 120ft/lbs on the stud, which in turn weakens the stud. I have no experience, but i read this from someone who was very serious about keeping people from doing it this way.
  6. tRustyK5
    Jul 23, 2000
    36,167
    1,365
    E-town baby!
    We used to get in trouble for using a nut and an impact where I used to work...better to seat them with a drift and a BFH.
    Rene
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Air hammer is my preferred method, followed by nut, washers, and impact.
  8. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    I used my press, pretty easy.
  9. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    Air chesel, blunt tip. In and out.
  10. 78GMC1/2TON4x4
    78GMC1/2TON4x4 1/2 ton status
    Mar 10, 2003
    167
    Mount.Angel, OR
    hammer them back in witgh a punch or something on the back side of them and drive 25mph for 5-10 and keep re tightening them... ive replaced 3 sets of the damn thing on the front end and they arent fun....neither is putting in wheel bearings....races...or replacing the SPINDLE /forums/images/graemlins/yikes.gif/forums/images/graemlins/truck.gif
  11. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    BFH/punch and plenty of re-torques if it is being fixed in the rough but other than that a press is so much better in my opinion .
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That's easy stuff. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
