pressing out wheel studs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by xnoahx, Sep 25, 2001.
  1. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    Ok, i need to fix my lug studs on my front wheel. How do i get these out? Do i need a press or what?
    My 73 K5 <a target="_blank" href=http://www.geocities.com/xk5blazerx/73k5.htm>http://www.geocities.com/xk5blazerx/73k5.htm</a> 350/TH350/NP203, Q-jet, Edelbrock intake, Vortec heads, 4" lift, and 36" TSL's
  2. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    BFH
    <font color=blue>Esteban</font color=blue>
    <font color=red></font color=red>
    <a target="_blank" href=http://coloradok5.com/gallery/Estebans-album>Take A Gander At My Truck Here.</a>
  3. Esteban86K5
    3,712
    Bakersfield, CA
    Then press them back in.
  4. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    My technique is to thread an old lug nut on them, and beat them out with a hammer, and then get them started with the hammer, and use yet another old lug nut and the impact to seat them.
    Special thanks to those lost from IAFF Locals 94 and 854 - You shall never be forgotten
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  5. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Ditto.
    "you know... the guy with the BAD A$$ spring perches!!![​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  6. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    If you don't have a press, I like to use a thick piece of soft metal (like alum. or brass) to protect the threads. Then use a sledge hammer and it usually only takes a couple of hits. I've had problems damaging the threads if I put a lug nut over the stud and pounding on the lug. The larger the alum. or brass block you have, the safer your hands are. Then I use the method above and use an impact with old lug nuts to suck them back in. Make sure to use antisieze lube.
    Shawn
    87 K5
    few mods [​IMG]
    <a target="_blank" href=http://www.off-road.com/chevy>www.off-road.com/chevy</a>
  7. Grim-Reaper
    7,385
    Atlanta
    2 things to add. any of the way's list below works but when you got the rotor (or even drum) off the hub or flange take a wire brush and get all the scaly crud off where they meet. light coat of high temp grease or antizise to keep them from rusting together. If there is crud between those surfaces you can get throb in the brake peddle and a shimmy in the steering wheel because it will change the runout on the disc or drum.
    After you put the lugs in drive it a couple miles and get on the brakes and get them good an hot. If the lug studs have not seated they will then. Recheck the lugs and make sure they are tight.
    Unfortunaly you will have to take the hub off to replace the front studs. I have a Balljoint/ujoint press and it works great for getting the rear axle studs out. Doesn't work on the front so the BFH and a old lug nut is what I do there.
    I don't need no damn shop manual, I got a pornographic memory.
    <a target="_blank" href=http://communities.msn.com/OffroadK5s>communities.msn.com/OffroadK5s</a>
    75 Jimmy, Dollar
    Grim-Reaper
  8. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Sometimes a bench vise can remove the studs. It can also be used to press them in.
    Poundin' the ol "pavment"!
  9. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    To remove ol' studs I use a hammer..... To seat the new ones I use washers, nut and a impact gun to........
    C'moe
    Kill Roy was here!
  10. 1bad82k5
    1bad82k5 1/2 ton status
    May 8, 2001
    185
    MT
    air hammer
    Don't get me started, you know how i get.
