Pressure for air horns?
Discussion in 'The Garage' started by newyorkin, Mar 16, 2002.
  1. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    Los Estados Unitos
    Hey all, I just picked up a pair of air horns and am getting set to put them in, but I have no idea what pressure to use. I gave them a puff with the 100psi air hose from my compressor (they sound like a dang frieght train!!), but I don't know if that will start popping seams if I end up holding it wide open in the road one day.
    I got them from a junkyard, so there's no packing or anything. I have a small electric "level ride" compressor I'm going to use to fill the tank until I get off my butt and put the York in, and a large PVC pipe as my tank. I don't know how I'm going to setup the release valve to actually use them yet, though....
  2. 4X4HIGH
    Dec 14, 2001
    Pleasanton, CA.
    What kind of air horns are they? Are they off a big rig? If they are off a big rig I have some going on my blazer and have tested to see what pressure it takes to make them work and found that anything under 40 PSI didn't work. I am going to check out NAPA for a air/electric valve to work the horns.
