Pressure lesson...
Discussion in 'The Lounge' started by Jagged, Aug 5, 2006.
  1. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    9 inHg pressure differential when rapidly depressurized with the right humidity can cause fog/rain.
    Long story short, we made a jet fog up and 'rain' inside today. If we had some colder air to start with we could have made snow :)
  2. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Damn! Your swamp coolers must cost a helluva lot to run!
    I bet that was something to see!
  3. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    "swamp coolers?"
    Used a couple -95's, and conditioned air thru the ACM as much as possible. We had to use aux heat the last two inches because the -95's weren\t putting out enough air.
  4. justhorsinaround
    Sep 16, 2003
    6,798
    Evaporative Coolers=Swamp coolers
    And my goodness. I can read all the words and numbers but have next to no idea what they mean when all strung together like that.:haha:
  5. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    -95 - air cart... small jet engine that has a powerful bleed air exhaust hose, used for starting engines (on some airplanes) and pressurization
    ACM - aircraft climate module (the air conditioner)
    aux heat - really hot air, easier to pressurize with than conditioned air
  6. justhorsinaround
    Sep 16, 2003
    6,798
    Ahhhh
    Ya see? When ya break it down into moron speak I can understand it muchly betterer. N stuff.
    So did it make enough moisture to actually make everything wet?
  7. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    We had about 80% humidity to start with, so when we depressurized, everything had beads of water on it.
  8. justhorsinaround
    Sep 16, 2003
    6,798
    Y'all need to try for real rain. A good heavy fog is definately a good start. Used to try to do this in the shower with really hot water then turn on the cold.
    By the way, I think it's a pretty damn cool experiment you did.
  9. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Interesting. At work we have a turbocharger turned into a Gas Turbine Engine (sic) for testing. Use a leaf blower to start it spinning. Sounds like -95 is just a really LARGE "leaf blower"?
    @ 9" Hg delta aren't worried aboot collapsing the building? :D
  10. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    Probably so. And on that note, I pressurized again yesterday up to 17.8 inHg. It's really neat for me. I'm working on becoming "all systems" qualified, and have been working with the Enviromental guys for the past couple weeks.
  11. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    full systems=less time off
