Pressure plate/bellhousing bolt torque specs
Discussion in 'The Garage' started by BowtieRed, Sep 6, 2003.
  1. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    What are the specs on the 6 bolts from the pressure plate to flywheel and the bolts from bellousing to engine? Thanks.
  2. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    My book doesnt give any specs, just says to tighten them. For the pressure plate, it says tighten in a cross cross pattern until the spring pressure is taken up. Just give the bolt a little "uh huh" with the ratchet and you will be fine. /forums/images/graemlins/thumb.gif
  3. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    ok, then i'll go with the hayne's manual specs for general bolts of a certain size.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I just tighten them til the lock washers are flat and they're nice and tight. Has worked great on the last three motors.
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    If the bolts are 5/16" tighten them to 15 FT/LBS.
    If the bolts are 3/8" tighten them to 25 FT/LBS.
    Make sure you are using pressure plate bolts and not just a regular bolt, pressure plate bolts have a special shoulder on them that locate in the bolt hole.
  6. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    My Chilton's manual said something like 40 ft/lbs IIRC.
