Pressure washer Q...
Discussion in 'The Tool Shed' started by 84gmcjimmy, Aug 23, 2006.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    My mom's boyfriend got a pressure washer from us for his birthday...
    I went to use it yesterday night to finish washing the jimmy...
    Filled it up with gas, put the garden hose on along with the pressure hose and gun. Turned it on and there was 0 pressure.
    What would cause this? There is lots of pressure coming from the water hose, nothing blocking the water filter, nothing clogging the hoses as far as I could tell(blew through them) and no SERIOUS leaks...
    Anyone?
  2. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    Someone allowed it to run dry, allowed water to freeze in it, or the crankshaft key is sheared.
  3. 78Buford
    78Buford 1/2 ton status
    Apr 1, 2005
    264
    Ohio
    How long did you let it run? The one I have takes close to a full minute to put out any pressure...once it has pressure, you can use it continuously without it losing pressure. The one I have is a Campbell Hausfield from Walmart...under $200.
  4. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    when you turn on the hose and pull the trigger will water come out of the wand without having the pressure washer turned on? It should.
    My guess is the pump was allowed to feeze and is fubared or it just lost its prime and maybe is "stuck"
  5. badfish4tail
    badfish4tail 1/2 ton status
    Mar 1, 2005
    1,684
    Long Beach
    Make sure the garden hose is turned on first before you try and start it, thats what also happend to me.
