Pressure Washer Questions.
Discussion in 'The Lounge' started by 83ZZ502_Jimmy, Jun 3, 2002.
  1. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Ok I have a 3500psi 4gpm pressure washer right now. I want to use a water tank to make it portable.
    Do I need a separate pump? Or will the PW suck from the tank. If so does this pump need to put out 40psi like a garden hose or????
    I have looked at all these trailer mounted washers and cannot figure it out. Maybe I should just call them..
    Anyone actually know?
    Thanks in advance,
    John
  2. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Check them out on ebay. If you can see the inner workings of the pressure pump, maybe you can figure it out...
