Pressurized gear oil container
Discussion in 'The Tool Shed' started by garlicbreath, Nov 19, 2006.
  1. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    Has anyone seen or made a pressurized gear oil container?
    I was thinging an airtight 2.5 gallon can, drill for a tire valve and put a hose on it with a valve.
    Pump it up to about 20psi with the tire valve and then just open the valve to fill my diffs and transfercase.
  2. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    friend of mine use to work for coke. he got 8-10 old suryip bottles. aluminum with black tops. he also got hose ends. he uses them all the time. all his fluids are in them . fyi the 20psi on gear oil might not be quite what you need to move thick gear oil.
  3. ryoken
    Jun 13, 2003
    29,621
    1,365
    Jersey Shore
  4. dremu
    Feb 27, 2000
    15,952
    442
    East of San Francisco
    I've been using a garden sprayer, similar to the one I used for my brake pressure bleeder, with good results. Hose-clamped a piece of ~3/8" clear plastic hose on the the thing, and just pump it up by hand.
    -- A
  5. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    im gonna try the garden sprayer for sure. i currently use a thread on cap with a tube to pour it in there but it takes FOREVER and a ton of squeezing.
  6. 94yukon
    94yukon 1/2 ton status
    Aug 20, 2005
    122
    Minnesota
    at NAPA I bought a gear oil pump from atd tools it was $34.00 +tax for a 5 gal pail it works good and oil is a little cheaper in bulk
  7. garlicbreath
    May 17, 2003
    1,136
    Denver
    I bought one of those pumps that fits on the gallon bottles.
    It works ok, works better if the gear oil is warmed by the sun all day, but I need to build something and this got the nod for now. That and a new welding cart with pnuematic tires.
