pretty blue smoke?
Discussion in 'The Garage' started by only 31s, Dec 21, 2005.
  1. only 31s
    only 31s 1/2 ton status
    Oct 5, 2004
    224
    mass
    coming out of tailpipe aftr driving for a while[10-15 min]if i stop and restart after cooling-exhaust is clean until driven again for a couple of minutes.I have an o2 sensor not giving any codes,i dont know about valves or rings could they be the cause?? 350 tbi 90. any help appreciated! Thanks!
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    Since it doesn't do it on start up, I would guess the valve seals are good. Do a compression test to see if you are getting blow-by on the rings
  3. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    is it on accel or on decel that you are getting the smoke? or is it after it idles for a while and then smokes when you pull off?
    my k5 used to load up with smoke when it was idling. pulled the valve covers and found that the oil drains in the head were plugged (thanks previous owners) and the oil would collect in the valve covers and then leak down through the valve stem seals. cleaned the holes, changed the oil a couple of times with a 1/2 qt of atf. no more smoke. not even at startup.
    just a thought.
    ryan
  4. only 31s
    Oct 5, 2004
    224
    mass
    it happens after initial idle-then while i drive and when i stop for gas or something,ive heard of the plugged head passages-ill try that next. Thanks!
