Preview of clocked 208!
Discussion in 'The Garage' started by outlaw612, Dec 16, 2003.
  1. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    I finally got some assembly pics today before I started the install. The adapter is a custom one made by Az-Kickin Offroad. The fixed yoke was done using Dodge parts.
    The pics are in my webshots which are linked in my sig line. Let me know what ya think.
  2. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Awesome! Are they ready to mass produce those things?
    The only question I have is:
    What do you do about the transfer case mount that is normally on the adaptor?
  3. outlaw612
    Feb 11, 2001
    2,342
    No, theyre not ready to mass produce. This is the first and Im still doing the install. I havent figured out exactly how the mount will work, but will be on the adapter. Ive got a couple of plans but nothing definate untill its in and I can get some measurements.
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    How do you plan to modify the stock shifter to work with the increased angle of the case? How much frame rail clearence is there?
  5. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    should make it so it mounts up across the top of the frame rail or something with a wrapunder skid plate... could use the clip-nuts that clip onto the frame...just my .02...
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    mind if I ask how much that adaptor cost you? I really want to clock my 208.
  7. outlaw612
    Feb 11, 2001
    2,342
    Im not sure exactly how everything will work since it hasnt been bolted into place yet. Once I get it all ironed out Ill do a write-up for Az-Kickin so they can decide how to proceed.
  8. outlaw612
    Feb 11, 2001
    2,342
    That is an option, Ill just have to see which will work best. The only problem with mounting on top of the frame is those people without a body lift may have problems installing it.
  9. outlaw612
    Feb 11, 2001
    2,342
    I dont know what the final cost of the finished product will be. The adapter was my design and Az-kickin built it since I dont have access to a lathe.
  10. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Any new info on this? /forums/images/graemlins/ears.gif
  11. outlaw612
    Feb 11, 2001
    2,342
    Im still working on it. I have found that the floor will need to be clearanced. The wire feeder went out on the welder so Im trying to get that fixed before I can get the crossmember and linkages setup.
