Previous owner idiot, distributor 180 off....Please help
Discussion in 'The Garage' started by GM Man, Mar 6, 2004.
  1. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    Well as the title says my distributor is off by 180 degrees. So now Im trying to fix and reroute the spark plug wires to there correct position, and I need your help. Could someone tell me where number 1 is on the distributor cap??
    Thanks /forums/images/graemlins/crazy.gif
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    USUALLY its pointed at #1 cylinder, best way to tell, put the engine at tdc and see where the rotor is pointin.
  3. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    If starting from scratch, number one can be anywhere on the distributer cap.
    With the number one piston at TDC of the COMPRESSION stroke, note where the rotor is pointing and go from there, following the firing order around and routing the wires accordingly.
    You bought a truck that ran like crap huh? Hope the deal was really good.... /forums/images/graemlins/waytogo.gif
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    the entire distributor ?
    is the vacuum advance on drivers side or pass side ?
    to set engien to #1 firing position, turn the engine by hand clockwise and with about half of a finger tip over #1 spark pluug hole feel for air being pushed out of the hole, now turn engine a little more slowly until timing mark on balancer is under the tab
    now pull the distributor and get soemthing like a normal car tire iron to turn the top of the oil pump rod so that the slot in the top of the pump rod is inline with #1 engine cylinder at its location in the engine
    now hold the distributor with the vacuum advance canister pointed to pass side of engine and make the rotor point at about #3 engine cylinder and drop the distrib straight down and maybe wiggle it and stuff to get it to fully seat down, if it wont then pull distrib back out alot of the way until you can turn distr rotor a little one way or the other but still keep it pointed near #3 cylinder, all until the distributor seats all way down
    wen it does then set the clamp bolt tight enough only until you can still turn the entire distrib but we its not real easy to judst mske it so that it takes one handful of force to twist and move it
    turn the entire thing counter clockwise a few degrees right now
    make note of what tower ont he HEI cpa that the rotor is going to point at if you put the cap on right now, this will be your #1 spark plug wire tower
    put the cap on now, do not turn the distrib at all again now until after all wires are run to cylinders.
    #1 tower to # 1 spark plug that you pulled out earlier,
    now go clockwise for next tower, it is the #8 tower, so run a wire form that tower to the #8 soark plug
    next is 4, then 3, then 6 and then 5 and then 7 and finally 1
    all done
    stock intake manifolds show the cylinder number at end of each intake runner, aluminum and iron both., aluminum in the 50s and 60s and 80s 305's L84 and L69 etc. and also 77-79 or so years 2bbl 305 LB9 i think i forogt.
    the above is how ot setup the ignition system in stock original factory form, but in real life you can use whatever tower ont he cap as #1 that the rotor is pointing at when the #1 cylnder ands valves are in firign order position, #6 will be in its firing position 180 degrees from there clockwise
  5. GM Man
    Jan 12, 2003
    549
    Denver CO
    Wow thanks for all of the feedback guys. Lots of good info and now my dumbass learned something new. I basically have to start from scratch due to number 1 on the cap being where number 6 or 5 should be.
    Thanks all! /forums/images/graemlins/waytogo.gif
  6. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    next is 4, then 3, then 6 and then 5 and then 7 and finally 2
    fixed it for ya
  7. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    It is possible to mix and match the above descriptions....
    You may 'get away' with just changing the order on the distributer cap if the wires will reach.... /forums/images/graemlins/thinking.gif
