Previous Owners suck thread...
Discussion in 'The Garage' started by sled_dog, Feb 5, 2004.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I know there have been plenty but now I have another vehicle to complain about. I do maintenence on my Suburban in between customers at work. Check fluids and everything trying to see if there are any leaks. So far everything is fine, I finally decide to pull the air cleaner lid off and look at the filter. I go to do it and the lid won't come off! I figure its rusted on so I pull the whole assembly off. Use some carb cleaner and clean up the TB which is pretty cruddy. I look closer at the air cleaner and realize the PO used black rtv and glued the air cleaner lid to the air cleaner assembly! He must have thought it didn't seal well enough or something. /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif
  2. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    I had a 383 I purchased years ago that some POS /forums/images/graemlins/angryfire.gif used JB Weld to keep the distributor from slipping! /forums/images/graemlins/angryfire.gif What a PIA it was to get that distributor out and clean out the clamp bolt hole! /forums/images/graemlins/angryfire.gif! Stupid people shouldn't breed!
    Bill
  3. atlantak-5er
    atlantak-5er 1/2 ton status
    Aug 20, 2003
    225
    Atlanta, GA
    My 75 had ghetto blue home carpet /forums/images/graemlins/peace.gif inside it with some of those rear capitans' chairs out of a mid seventies conversion van. It also had some half arse rigged stereo system that almost burned my K5 to the ground the 1st day i bought it! The second day I had it I gutted it and lined the tub!
  4. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    [/ QUOTE ] No kidding! I agree! /forums/images/graemlins/ignore.gif /forums/images/graemlins/shame.gif
  5. tweek
    tweek 1/2 ton status
    Aug 13, 2003
    353
    montgomery, ny
    some retard mixed concrete in the back of my pre-owned k5 /forums/images/graemlins/dunno.gif then thought if he vacuumed the rug no harm no foul.......however the lie in the cement ate away the tail pan /forums/images/graemlins/angryfire.gif....that was the only piece of rust on my truck........since been replaced..........the nerve of that S.O.B for using the truck the way he needed /forums/images/graemlins/doah.gif
  6. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    Got ya all beat. My PO ordered the blazer from the factory with 2.73 gears "to improve towing performance in the mountains"...yes he actually said that to my face when I bought it. It's ok though his eyes looked a little funny so i think he just finished hitting his crack pipe.
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    oh if you want to talk PO of K5s, my PO told me the K5 had a crate 350 and 3.73 rears. Truth? stock factory 305 that burned oil like mad and died on me. Rear? 2.73 gears with a bad pinion bearing.
  8. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
    My dad's neighbor used a bunch of bags of quikrete for weight in the bed during the witer a couple years ago. Needless to say, when the snow melted he had a hard time gettin the concrete chunk the width of the bed out.
    And unfortunately the guy had more kids than fingers. /forums/images/graemlins/rolleyes.gif
  9. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    previous owner put a new tailpan in......
    Of course he didn't hook the fenders back to it, and stupid me when I heard tailpan was fixed I ASSUMED the floor was OK /forums/images/graemlins/rolleyes.gif
    PO, put on a newer tailgate.......
    NO key and it doesn't lock and the tailgate handle is broke /forums/images/graemlins/doah.gif
    had a return fuel line leak....
    PO, cut the lines and spliced in rubber lines
    PO also replaced the brake lines with the cheap roll lines and never hooked them up to the frame or axles... the lines just ran which ever way and was hanging /forums/images/graemlins/angryfire.gif
  10. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Hmm, the only thing I can blame my PO for is plowing snow all winter then parking it all summer without so much as a spray with the hose /forums/images/graemlins/shame.gif
    Actually, I'm the idiot PO who people will blame in the future. I do so many half-assed and crazy fixes to my truck it's ridiculous. /forums/images/graemlins/peace.gif
  11. screamer*145
    screamer*145 1/2 ton status
    Oct 23, 2003
    174
    cottage grove, mn
    my PO had a rope to hold the trans/transfer case adapter to the crossmember. /forums/images/graemlins/shame.gif
    PO said the motor had been rebuild and about 4 months later it took a crap when I found coolent in the oil pan /forums/images/graemlins/doah.gif!
  12. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    the PO of mine drilled 2in holes in the bottem of the air cleaner box BETWEEN the carb and filter. /forums/images/graemlins/confused.gif /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  13. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    [/ QUOTE ] Mine did the samething but he informed me of it before I bought the burban and made sure it was ok by me.
  14. Roshambo
    Roshambo Registered Member
    May 1, 2003
    50
    South Coast, OR
    Well, I bought my truck with a tired 350, it originally came with a 400 but running the block numbers told me otherwise.. I figured I would wheel it until it went because I had a motor already built up anyways. When I got a rod knock I decided it was time to pull it out.
    I already knew the previous owner was an idiot, but when I started pulling the motor I was amazed. All of the motor mount bolts were finger loose. The TQ convertor was missing bolts and the ones that were there were mismatched... basically it seemed like whoever did the half ass job of installing the POS motor forgot to torque down anything. /forums/images/graemlins/doah.gif
    -Joe
