price and fitment of 14 bolt.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mudstud, Dec 16, 2001.
  1. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    So what kind of price is fair on a 'turn key' 14 bolt sf or ff? I don't know the gears and neither has a locker. Both are out of a 3/4 ton. I'm not sure of the year they are out of.
    If these are out of 2wd trucks the shockmounts on them will be the 'longer' kind (the ones that hang down below the axle)
    Am I on track?
    Mudstud
    <a target="_blank" href=http://communities.msn.com/OffroadK5s>http://communities.msn.com/OffroadK5s</a>
    76K5 6" with 33s, sb400/350/203parttime/3.73-D44/GM12bolt
  2. vince13
    vince13 1/2 ton status
    Dec 6, 2001
    105
    Penticton, BC Canada
    Get the full floater if you can, and no the 2wd drive as far as i remember are the same shock mounts as a regular 4x4 14 bolt. should just bolt right in.
    73 Blazer 1Ton 6inch lift, 3 inch body, 36 inch swampers
    79 3/4 ton suburban, soon to be 6 inch lift, 3 inch body, and 44 in boggers. Oh ya
  3. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    The FF that I used was out of a 2 wheel drive.
    I had to blow the mounts off and relocate them, with the shock fully extended they were not even close to going in.
    Shannon(mudhog) had the same thing when he swapped his out, he used longer shocks on his.
    Before I took the 12 bolt out I measuerd the shock with the axle at full droop and placed the shocks at the same measurement on the FF.
    <font color=green> Too bad ignorance isn't painful </font color=green>
  4. Gold Rush
    Gold Rush 1/2 ton status
    1,498
    Savage1 and I pulled a 14 FF out of an 80 2WD and it bolted right up to my 75 Blazer. The whole cost of it drum to drum with e-brake cables and u-bolts cost $120 from a junk yard here in California. It is open with 4.10 gears and wasn't hard for me to weld up the spiders.
    David
    <a target="_blank" href=http://www.extremeblazer.com>ExtremeBlazer</a>
  5. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    I got mine for $95 from the junkyard Complete. cou;d have just bolted it right up. And yes you are correct about the shock mounts being lower on a 2wd axle compared to the 4wd axle. I just relocated my rear shocks al together and solved that problem.
    <font color=blue>It's easier to teach a child than to fix an adult.</font color=blue>
    <a target="_blank" href=http://community.webshots.com/user/geltyone>Webshots Pics.</a>
