Price for this axle?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fourwheelinj1, Nov 26, 2002.
  1. fourwheelinj1
    fourwheelinj1 Registered Member
    Sep 18, 2002
    18
    Wake Forest North Carolina,USA
    There is a guy locally selling his 3/4 ton dana 44 because he just upgraded to a dana 60. I wanna know what you guys think this axle is worth. I am going to do /forums/images/graemlins/rolleyes.gif a 3/4 ton swap in spring and this seems to be just what i need.
    All seals new except pinion seal, he said it leaks.
    -1976 Chevy 3/4 4X4 front axle with 4:10 gears.
    -Lockrite that was bought in August 2002.
    -New Calipers that have been ground to fit 15" wheels.
    -Chrome (but slightly dented) diff cover
    -MileMarker Premium external lockouts.
    -All new wheel bearings and races.
    -12 month old tierod
    -New -297x u-joints
    -Moog ball joints
    -4" raised GM steering arm
    NOW......It also includes all of the following spare/extra parts.
    -1 pair MileMarker external lockouts.
    -2 long side axleshafts
    -1 shortside axleshaft(I prolly have more)
    -3 stub shafts
    -1 Passenger side flat top knuckle for x-over steering (knuckle not machined for steering arm.
    I replaced the inner axle seals when I installed the lockright in August, and I parked the truck on a hill for 10 days and found a couple of drops of 80-90w on the tire, so I am not sure if it was coming from the inner axle seal or just some residual that was in the axle tube.
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    300-400 imo
  3. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I would buy some broke down 4x4 3/4ton from the junk yard and rebuild both axles (matched pair most likely). But if most of the parts on this d44 are new maybe $350?
