price on caddy 500
Discussion in 'The Garage' started by HillJackCustoms, Oct 11, 2006.
  1. HillJackCustoms
    HillJackCustoms Registered Member
    Apr 19, 2005
    64
    Indiana
    is 700 bucks a good buy for a caddy 500?? it ran when it was pulled
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    that seems like a little much, these engines tend to be pretty cheap normaly, i sold a 472 that was liek brand new for only 200
  3. HillJackCustoms
    Apr 19, 2005
    64
    Indiana
    icic should i check junk yards for the motor?? Im not gonna find one around here for sale... what should be an average price for one??
  4. BadBob
    BadBob 1/2 ton status
    Aug 14, 2005
    158
    Lyndon, KS
    I've seen a pair of fairly nice 500 eldorados go for $400 total.
  5. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I got a 500 with what is supposedly a bad coil and the matching, working TH400 for $200 total.
    Haven't tried to get the motor running yet but I'd say $700 for a motor alone is pretty high.
  6. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    bought a '75 eldo & a '70 coupe deville for $700. took the '75 500 & the heads from the '70 472 (they are the 950 "no smog" ones). then sold the 2 cars & the 472 w/ the late model 500 heads for $750 + a BOP t-400 core
  7. HillJackCustoms
    Apr 19, 2005
    64
    Indiana
    aight well thanks everyone... im gonna talk the guy down in price... it is a salvage yard that has it... if he won't go any lower... im not buying it... so around 500 or less for a whole car i should be looking for??
  8. diesel4me
    Jul 24, 2003
    17,579
    945
    Massachussetts
    here they get...
    Junkyards here get a dollar per cubic inch on most V8's--so you can expect to pay at least that for a good running Caddy 500..they are not as plentiful as people lead you to believe anymore,at least not here!...here,big block chevy motors sell for at least a grand,even high milage ones that run,but need rebuilding!--IF you could even locate one!..
    That is why the Caddy motors started gaining popularity--it used to be you had a hard time finding ANY big block chevy motor--now the scales are tipping the other way..many newer style 454's are starting to show up in the junkyards from the 90's trucks now,and about every Caddy has been bought up and they are getting scarce here now..the newer 454's are not as popular with the hot rodders with older vehicles though--swapping in the TBI,and other changes made to the blocks prevent some from using them..
    I have a 1976 Caddy 500 and TH400 in my shed..its been sitting for about 8 years,I was going to use it,but now it will likely need to be rebuilt--it was from a Coupe Deville,and ran ok,but had over 100,000 miles..It turns over freely,but I would probably not use it in its current state..I'm only keeping it in case I blow my 6.2 up.or I might just sell it,or trade it to a junkyard guy I know, for another diesel motor, if mine craps out..
    If you get a whole car,the Eldorado has the rear sump oil pan you'll need to swap the 500 into a GM truck--be aware they are a bitch to pull the motor out of though!--if you can do it without cracking the bell housing,you will be lucky--we pulled dozens at the junkyard,and only about 5 came out with no bellhousing damage..but you CAN sell the transaxle for good $$$ on E-bay,as many owners are having difficulty finding a rebuildable core with no bell housing damage..We started cutting the CARS up to pull the motors,since few of the bodies were much good anyway,to prevent losing $$$ by ruining the trannys..:crazy:
  9. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i got my car for 425 i think, with the engine from ebay
  10. smalltruckbigcid
    smalltruckbigcid 1/2 ton status
    Dec 25, 2004
    3,866
    3
    NE Wyoming
    I bought a 76 CDV with 53,XXX miles running for $300. And 5 other engines that ran for $125.each....I got caddy motors
    George
