Price on GM crate motors??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BLzr4x4ngkid, Oct 16, 2000.
  1. BLzr4x4ngkid
    BLzr4x4ngkid 1/2 ton status
    Feb 18, 2000
    703
    Wichita, KS
    Can anyone tell me if GM makes a crate 383 Stroker? I know they have crate 502's and 350's. Since the out look for insurance and a counter lawsuit are looking really good right now, I was thinking about dropping a big crate motor in my next Blazer. I think the 502 would be too much and I could gladly settle with a 330hp 350, but I would really like a 383. Does anyone know the prices on......
    350, 350 w/330hp, 383, and/or 502.
    Thanks a bunch.
    Alex
    [​IMG]What me get stuck? NEVER!![​IMG]
  2. Hayduke
    Hayduke 1/2 ton status
    May 9, 2000
    271
    NE Columbus, Ohio
  3. BLzr4x4ngkid
    Feb 18, 2000
    703
    Wichita, KS
    Come on guys, someone has to know something about the prices? Please? I love ColoradoK5? HAHAHA
    Alex
  4. 1HIHUM
    1HIHUM 1/2 ton status
    Jun 28, 2000
    366
    Fremont, CA
    The 383 crate motor goes for about $2700. you can get all the info you need at www.paceparts.com, or call your local chevy dealer! I went with the ZZ4 my self. But if I had the money, the ram jet 502 would be blowing apart my drive shafts!!!
  5. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    330hp/350 $2,000.00
    ZZ4 $3200.00
    LT4 $4300.00
    425hp/454 $4100.00
    440hp/502 $4900.00
    to
    602hp/502 $10,000.00
    All ball park figures. Shipping etc, extra.
  6. sosamantx
    sosamantx 1/2 ton status
    Aug 14, 2000
    393
    somewhere in Texas
  7. realsquash
    realsquash 1/2 ton status
    Jul 12, 2000
    778
    SE WI
  8. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Here it is
    The part # is 12497317 and I found it at http://www.paceparts.com goto GM Performance Parts and click on crate engins, the Pace Price - $2,679.95
    check out the numbers
    Horsepower 325 @ 4500 RPM
    Torque 415 Ft. Lbs. @ 3500 RPM
    YaaaaaHoooooo
    http://www.burt4x4.coloradok5.com
  9. SilverJim
    SilverJim 1/2 ton status
    Sep 23, 2000
    105
    Evergreen
    a 502 is NOT too much, i just dropped one in my '70 Jimmy, it fits like a glove...used the same bellhousing, tranny, but did swap the Dana 20 for a 205. One thing to keep in mind with the crate motors: you will spend a LOT more on other parts such as: carb, distributor, exhaust, coil, and everything in between. Also, the 502's don't have a mechanical fuel pump boss, and I would make sure that the small blocks do if that is a concern of yours.
    1970 GMC Jimmy (still waiting to put the body BACK on the frame)
  10. BLzr4x4ngkid
    Feb 18, 2000
    703
    Wichita, KS
    Mechanical fuel pump boss, what's that?? Also, is it possible to make it fuel injected or is it just carb'd?? Thanks for all the responses.
    Alex
  11. SilverJim
    Sep 23, 2000
    105
    Evergreen
    the mechanical fuel pump boss is just the hole in the side of the block that the lever on a mechanical fuel pump slides into. you can make it fuel injected if you want or carb'd, just depending on how much you want to spend. I wanted the Holley Pro-Jection, but the cost is prohibitive. look on the side of your old block where the mechanical fuel pump is bolted, if you were to remove the fuel pump, you would be looking at the boss.
