price quote for custom rear shock mounts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wayne, Feb 6, 2001.
  1. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Well I did all the leg work and here is what I found.
    Scott at rockstomper.com (303-833-1431) can supply a kit like on Steve's K5 for around a $100.00 including shipping. The kit would include upper bar that would need to be cut to length (because frame widths vary) and the ends would need to be welded on. Lower mounts would need to be welded on also. Shocks (If you are running the same lift as Steve) you would need to get are Rancho part # RS9012 or similar. You will also most likely have to modify your exhaust. Hope this helps out. Thanks Steve for all your help!!!!!!
    Scott at rockstomper.com (303-833-1431) The phone # is also his fax #.
    Happy Trails
    Wayne
  2. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    Re: price for rear shock mounts
    Thanks for all the work I will have order the setup thanks agine
    Bo
  3. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    No problem Bo just helping everyone out.
    Happy Trails
    Wayne
  4. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Anyone have any input on if this setup would hurt towing a trailer? Also how would it be on a dailey driver?
    Happy Trails
    Wayne
  5. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    Scott did the rear of mine a few months back. Seems to work very well. NO COMPLAINTS!!! Just find a good welder to do the welding for ya and you will be good to go.
