Primer work through one winter???
Discussion in 'The Garage' started by tayv, Oct 17, 2003.
  1. tayv
    tayv Registered Member
    Apr 3, 2003
    58
    Seattle, Wa
    If i just used some spray can primer to coat my truck will it hold up through the rain of one winter? I know it will last for a while but just how long. I need to get it out of the garage. If any of you are running an all primer rig, your info would be greatly appreciated. THank you!!
  2. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    If you did a good job and let it dry fully before getting it wet, primer will last a looooong time.
  3. tayv
    Apr 3, 2003
    58
    Seattle, Wa
    Thanks alot. I am tiredf planning and waiting for the right paint and the right time to pain it. I want to go out and try to break it!!
  4. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    i have primer on my rig.it lasts a couple of months then the rust starts popping out.check my link below to see it.
  5. rugger03
    rugger03 1/2 ton status
    May 14, 2000
    829
    around
    Primers are all different, but most spray omb primers wont hold up very long, They are pretty porous and allow moisture to soak through this is why the rust comes through the primer. If you want to leave it in primer and have it hold up, expoxy primer is about the only thing that will do what your looking for.
  6. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
    laquer primer is very porous, don't use it. enamels and epoxies will last quite awhile providing you get adequate coverage.
  7. Snowbound
    Snowbound Registered Member
    Mar 12, 2002
    52
    Minot N.D.
    Got some industrial grey primer from walmart .94 cents a can took 3 months to rust through. /forums/images/graemlins/crewcab.gif
  8. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Even if you can't see the rust, it will form under the primer almost immediately. You will need to strip it off and reprime if you're going to paint it and want it to last. If you want a truck that's primer then check out Zerorust paint. It's not as flat as regular primer, it's semigloss, but it is designed as a rust preventative coating and will last as a topcoat. Cheap too, only $50 for a gallon of black. Not sure how much it is for rattle cans.
  9. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Sealer primer, unless you want more rust.....
