Priming a Diesel? (put gas in a diesel)
Discussion in 'The Lounge' started by 90blzr, Apr 1, 2005.
  1. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    My neighbors kid accidentally put gas in the diesel tractor. Its an old Ford Tractor. So he drained all of the gas out, put the diesel in, and it wont fire. Might it need to be primed?
    If so, how do you go about doing that?
    Any ideas?
  2. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    crack all the injector lines open at the injectors, turn the motor over, once you start getting diesel up there close them up while its being turned over....works on most older diesels
  3. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    cool, sounds easy enough! How does he know when all of the gas is out and its only diesel going through?
  4. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    mike... do what bowtie said....
    when the fuel starts coming out you will feel the lubricity of the diesel....
    normally the fuel wont have any air bubbles anymore after its bled for 5 or ten seconds....
    this is a common occurence when you run diesel tractors out of fuel... its no big deal
    a little gas wont hurt anything and will burn up anyway.... some truckers used to mix a little gas and other oils into their diesel to raise the cetane rating.... I dont recommend it because it can do harm over the long term to the engine and pump (gas has little lubrication) but one time a little gas should fire right off
    cam
  5. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Is there a hand pump near the fuel filter? If so put on a new filter with out any fuel in it and hand pump it. There should be a "slobber" hose that the fuel/air bubbles will drain out of. Just pump it untill the bubbles are gone. Always make sure You use a dry filter otherwise you will just be putting nonfilterd fuel into your injectors.
