Printed Circuit Boards In Dash?????????
Discussion in 'The Garage' started by Bubba Ray Boudreaux, Jun 19, 2005.
  1. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    WTF do they do exactly????????????????
  2. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Are you referring to the sorta-flexible one behind the gauge cluster? If so, that's what powers the gauges . Why the General did that... who the hell knows.
  3. tiger9297
    tiger9297 1/2 ton status
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    had to replace mine a few months ago. i agree that's not a good way to run the instruments.
  4. dyeager535
    26,979
    You mean short of supplying +, -, to the gauges, various bulbs, (illumination, high beam, turn signals, check engine/choke, 4wd, brake, plus idiot lights if not gauge equipped) and carrying the output of the various senders/sensors to said gauges?
    I'm sure GM did it partially because it's a good way to cut down on clutter, wiring hassle/expense, maintenance, and how deep the dash needed to be. Nothing at all wrong with PCB's, think of one electrical device that doesn't use one. (well, ok, one that doesn't use a circuit board of one type or other) Not to mention every GM vehicle I can think of, 1970's into at least the 1990's.
    A single connector into the back of the cluster makes more sense than 18 wires terminating in seperate locations.
