Pro-comp 4" front-spring Q
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Espen88k5, Apr 6, 2001.
  1. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    There are diffrent size holes through the two polyetran-bushing metal cylinders? Is one bolt smaler than the other on the same spring? And the spring did not come with a arrow to indicate which way it goes inn. Can anyone tell from the picture which is which? (one side has 2 spring clamps, the other just 1). This is for the front and my Blazer is an 88.
    <A target="_blank" HREF=http://www.espen88k5.coloradok5.com>http://www.espen88k5.coloradok5.com</A>
  2. AMorris1
    AMorris1 Registered Member
    Mar 9, 2001
    8
    Fremont, CA
    Re: Pro-comp 4\" front-spring Q
    I just put the exact same springs in mine. The left side (larger bushing) goes towards the front. I believe if I remember correctly, it is impossible to put them in backwards, because the bolts are different sizes.
  3. JoeAngelicchio
    JoeAngelicchio 1/2 ton status
    Feb 18, 2000
    628
    South Central Ontario, Canada
    Those look exactly like my Rancho 86206's. I saw a chart once and the spring rates where the same.
    <font color=green>Joe Angelicchio
    86 Jimmy 4+3, 35-&gt;39.5 tires,4spd
    </font color=green>
    [​IMG][​IMG]
  4. Espen88k5
    Feb 19, 2000
    981
    Norway
    Thats what I thought also, that once I was down there on my knees actually fitting it to the frame it would become selfexplainatory(sp!)[​IMG]
    Can you shed some more light on how you did the lift. Where you put the jacks. In which order you did the install etc..
    I have a strong air-compressor and all the air tools I could wish for. I also have been spraying rust-loosner for several weeks. I am thinking about using a air-hammer downwords/sideways/everywitch way on the steering arm, and I think I will just cut the U-bolts with the grinder. .
    Any input that could help this become less painfull grately apreciated.
