Pro Comp 6" lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dj-beeker, Jun 8, 2002.
  1. dj-beeker
    dj-beeker Registered Member
    Jun 7, 2002
    13
    Pro Comp 6\" lift
    This looks like a good deal. It comes with the kit, extended brake lines and a steering arm.
    Pro Comp 6" Lift kit
    How does this compare to other lift kits?
    How hard would it be to install this for someone that doesn't know much about trucks? What kind of problems will I run into?
    I have a basic socket set and a few other tools. I would need to buy a jack stand but those aren't very expensive.
    Any insight is greatly appreciated!
    Jeremy
  2. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    Re: Pro Comp 6\" lift
    In my opinion that is to much money for a lift.
    Colin
  3. dj-beeker
    Jun 7, 2002
    13
    Colin,
    What do you recommend?
    jeremy
  4. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    too expensive for rear blocks.
    NITRO
  5. CK5
    May 19, 1999
    21,625
    702
    CO
    I am suposed to be getting some dealer info next week for procomp, have no idea on there pricing structure or anything but might want to check with me next week just in case I do carry them maybe cheaper.
  6. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    I sell the same kit out of my shop with 4" blocks and add-a-leaf for the rear, and inlude the shocks, brake lines, steering arm, etc. for $550.
  7. dj-beeker
    Jun 7, 2002
    13
    Is this a 4" lift or 6" lift?
  8. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    6" lift.
  9. dj-beeker
    Jun 7, 2002
    13
    Swanson52,
    How easy is it to install this 6" kit? Will I need anything else besides what comes in the kit? If not much else is needed and your a re-seller do you have a contact number or website that this can be purchased from?
    Jeremy
  10. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    Sent you a PM.
  11. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    My experiance with procomp lifts is they ride like a brick. The ride sucks!!!
    I've got a rough country lift and it rides nice and flexes pretty good. I paid about 300 for a 4" lift with rear blocks and later got rear springs
  12. DUKE
    DUKE 1/2 ton status
    Nov 14, 2001
    879
    Davenport Iowa
    Some must haves i have found recently are a good rachet or bar of considerable length. At least a propane tourch to heat up some bolts. I still had to take mine in to someone with a cutting tourch to get some rear leaf bolts cut off, as they were so stuck. (i broke a few sockets and decent ratchet /forums/images/icons/mad.gif ) I would also suggest the rough country route.
