pro comp brake lines
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chris77k5, Nov 26, 2001.
  1. chris77k5
    chris77k5 Registered Member
    Nov 26, 2001
    19
    washington,puyallup
    I'm new to this board and i want to know what you think of the pro comp brake lines i am thinking of buying a set how much do they go for thanks
    77 k5 400sb, edelbrock rpm, carter 625,4" rancho 3" body, 3.08 10bolt 12bolt 33-12.5 soon to be 4.56 and 35s bfg km
  2. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
  3. chris77k5
    Nov 26, 2001
    19
    washington,puyallup
    thanks for the info
  4. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    I just bought the set from Summit. I like them.. However what I don't like is that I messed up the threads on the rear and instead of procomp selling me the piece I need they will only sell me the complete rear line for $70. That kind of ticked me off but what can ya do? BTW if anyone knows where I can get the brass block that bolts to the pumpkin of the rear axle I would appreciate it. Kinda sucks having this SS line and not able to use it.
    89 K5 Silverado, 4", 33's, 3/4 ton axles
    <a target="_blank" href=http://mudfrog.rockcrawler.com>http://mudfrog.rockcrawler.com</a>
  5. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    I got them and love them!
    Don't hit me, Mr. Moderator... I'll go back on topic... I swear![​IMG]
    <a target="_blank" href=http://www.geocities.com/muddin4fun79blazer>www.geocities.com/muddin4fun79blazer</a>
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I don't mean to barge in on your post, but I got a question about the Pro Comp brake lines. I have 21/2" of lift, and am going to add the ORD 1" add a leaf for a total of 31/2 "s. I know I need extended front line, but do I need extended rear line too? Thanks
    Harley
    My Chevy isn't broken, its just out of gas.
  7. hammer
    Aug 29, 2001
    449
    Binghamton N.Y.
    the brake lines are good for up to 6" of lift. Just jack the body up and see you should have enough slack in the lines left
  8. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Installed them on my truck and really like them, they are made really well.
    1987 Jimmy Sierra Classic, Palisades Park, NJ 07650
  9. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Thanks. I learned here that I need new front lines. I found that was true this weekend. I was out shootin, and I was going threw a washed out area, that wasn't to bad. I got out and looked at my break lines, and most of the slack was gone. I didn't even have the swaybar disconnected either. So new brake lines are a Xmas gift to myself. I know I must have stretched them pretty far before. Kinda scary.
  10. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    I like the ProComp lines, I put them on my Jimmy about 3 months ago. Good times...other than the fact that I never could get the factory rear brake line fittings off...grrrrr. =\ Someday I'll have the time constantly soak them like mad with WD and they will finally budge. ;)
    J
    See the on-going build up of my '85 Jimmy! http://community.webshots.com/user/jekbrown
  11. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    FYI. Pro-Comp Lines are not DOT, Buyer be wear !
  12. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Executioner.... They are DOT approved. Says so on the package and on a rubber tag around the hose itself.
  13. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Ex that used to be the case but not for the past few years. Skyjacker's are also DOT approved. I have the ProComps on the '80 &amp; the Skyjackers on the '73. The front is the most important. The rear can be corrected, up to a point, with a new bracket because it is in the center of the axle not at the ends.
    Jim '80 GMC & '73 Blazer
    Body by Tellico
    <a target="_blank" href=http://www.tellicok5.rockcrawler.com>www.tellicok5.rockcrawler.com</a>
  14. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    i love mine!!!
    <font color=red>K5: Because size DOES matter</font color=red>
    85 K5 4IN LIFT 35 GOOD YEAR WRANGLER MT/R, AMERICAN RACING WHEELS
  15. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    ProComps are made for ProComp by Earls Performance who's been making lines for eons. Both kits have fron and the rear lines. Cost of just the fron new replacement OEM style were more than the complete set from ProComp. I've had mine on for two years and no problems yet even with the disc brake conversion. Wish I could find a set to mate up to the new rear calipers now....
