pro comp shocks
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Russell Keys, May 26, 2000.
  1. Russell Keys
    Russell Keys 1/2 ton status
    Mar 16, 2000
    253
    Huntsville, TX
    I just wanted to know if anyone here runs pro comp shocks. I have a set on my k5 that I got off a parts truck, and I don't think they're the right ones. Does anyone know the part# for front shocks with a 4"lift. Mine only have about 4" of downtravel. Also I run the same lift on my 81k30 and the rear shocks won't mount right side up because the shock "body?" hits the axle tube. Both are 14 bolts and both are pro comp and the ones on the k5 are fine. Does it hurt a shock to be mounted upside down?-Russell
  2. bigdaddy89
    bigdaddy89 1/2 ton status
    May 18, 2000
    422
    Phx, Az
    If the shocks are es3000's then the front part# would be exp322500/rear exp326500. Running your shocks upside down shouldn't hurt them.
