pro comp stainless steel brake lines
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by hoserr, May 29, 2002.
  1. hoserr
    hoserr Registered Member
    Jul 25, 2001
    78
    chula vista, ca
    hi there out there in hub locking land, has anybody used the "procomp" stainless steel braided brake lines. i'm in need for some longer brake lines and it seems they're the only manufactures out there.
    Hoserr
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Yep I use them..I'm happy with them.
  3. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    same here. Dunno if they are gonna be long enough... after the long-travel shock upgrade (ala UAV) I'll know more. /forums/images/icons/wink.gif
    I know skyjackers sells longer brake lines too... and, of course, you can always have a race shop custom make 'em for ya. /forums/images/icons/smile.gif
    J
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I have them too.
    The rear one was only like 2" longer than my stock hose...I think that is just a 1st gen thing. I think they will be plenty long for your lift.
  5. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    installed last weekend with no probs...i like them so far.
  6. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    superlift sells em too...national tire and wheel and tyres international carry em
    Later
  7. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I have them. ProComp does not make them,. Earl's does. Procomp just sells them.
    They work great, several years old and no problems.
    -- Mike
  8. hoserr
    Jul 25, 2001
    78
    chula vista, ca
    i went to earl's first and they didn't have the right connectors, so i order'd a set from summit. we're going to the baja 500 on friday and i wanted to be sure i had no problems with the brake lines. it will be interseting using a K5 in this capacity. thanks guys. Hoser
  9. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    I use the procomp lines (earl's) and they work great. No problems with them whatsoever. Superlift does sell them and they make them up to 11'' longer, so depending on what your suspension does, you might wanna check them out. 4WPW sells both of them at decent prices.
