Pro Rock 60
Discussion in 'The Garage' started by Z3PR, Mar 28, 2003.
  1. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Anyone running one of these ?? Whats your opinion ??? How much did it cost with everything including shipping to your door ?? [ QUOTE ]
    Dynatrac manufactures Hi-pinion housings designed to fit GM trucks better than any other housing available. The Dynatrac Hi-pinion housings are made from 100% nodular iron in the USA.
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> That axle is probably over $5000, easy. </font>
  3. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Available to the public immediately, the Pro Rock 60 costs $995.00
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Here's a quote I got:
    DYNATRAC www.dynatrac.com
    PRODUCTS CO., INC. Effective: March 28, 2003
    7392 Count Circle · Huntington Beach, CA 92647-4551 · (714) 596-4461 · Fax (714) 596-4449
    68 Thru 91 GM Pickup &amp; Blazer
    Pro 60 Hi-pinion Front Axle
    Part No. GM60-3002-A
    Axle Package
    Complete Dynatrac 60 axle assembly with 12 month limited warranty Included
    Axle is set-up for an application with a passenger side offset pumpkin Included
    Dynatrac Pro 60 Hi Pinion housing Included
    Includes Warn heavy duty manual locking hubs Included
    SD 35 Spline, 1.5&amp;#8221; induction hardened alloy steel inner axle shafts (uses 1480 axle joint) Included
    HD disc brake assembly with a 6 on 5.5 bolt circle Included
    Choice of ring and pinion ratio (3.54:1-5.13:1) (5.38 available, call for pricing) Included
    Open differential Included
    Best pinion angle and wheel alignment for 4-6&amp;#8221; lifts (max. warranted pinion angle - 11 degrees) Included
    D60 heavy-duty steel differential cover Included
    1310 U-bolt style yoke (U-bolts included, Other yokes available call for pricing) Included
    Dynatrac Pro 60 knuckle, Pro 60 wheel hub &amp; spindle package Included
    High clearance u-bolt and spring plate kit (Subtract $159.00 to remove) Included
    Width 69.25&amp;#8221; (Stock 67&amp;#8217; to 69.5&amp;#8217;) Included
    Assembly is finely detailed with a hi-gloss black finish Included
    _______________________
    Total $4604.00
    Upgrades:
    ARB Air-Locker $ 639.00
    Stainless ARB Line $ 69.00
    Detroit Locker $ 425.00
    Powr-Lok $ 349.00
    Hi-Clear. Steering $ 695.00
    X-over Steering $ 595.00
    Stainless brake hoses $ 109.00
    35 sp Premium hub &amp; outer shafts $ 298.00
    8 on 6.5 wheel bolt pattern (SRW) $ 0
    Notes:
    (Axle Top View)
    _______________________________________________________________________________________________________________
  5. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    Thats only the center section, nothing else.
  6. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> That's $4600 without even a locker. No thanks! /forums/images/graemlins/eek.gif </font>
    Axle Package
    Total $4604.00
    Upgrades:
    Powr-Lok $ 349.00
    Notes:
    (Axle Top View)
