Problem converting '70 Blazer to power steering
Discussion in 'The Garage' started by urbanhunter44, May 7, 2006.
  1. urbanhunter44
    urbanhunter44 Newbie
    May 7, 2006
    3
    directly above the center of the earth
    I'm trying to convert my '70 blazer to power steering from manual and I'm having a problem locating a part.
    The arm that goes from the box to the rest of the steering doesn't fit the new box and I can't find that arm. I believe it's either called a pitman arm or a steering arm? Can someone tell me exactly what it is and where to find a new one? Thanks
  2. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
    are you going for cross over? or conventional steering? and it is called a pitman arm. most would call the thing that attaches to the axle the steering arm. what PS box are you using?
    here are the two types.
    that is a typical 4wd box.
    this is a 2wd box used for a cross over converson. it has a ford pitman arm on it.
  3. urbanhunter44
    May 7, 2006
    3
    It's the stock box for a 4wd '70 blazer. I got a never installed new box.
    I tried ordering a moog pitman arm but it has a swivel joint at the end of it, and the arm on my car now (4wd manual steering) just has a hole at the other end that a bolt goes through.
  4. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    most pitman arms have a tapered hole for the DLE to go into. im not familar with first gen stuff so i dont know what the factory setup would be,
  5. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I think you may have a 2wd box and not a 4wd box, AFAIK all 4wd boxes use the same pitman arm that when installed points toward the drivers side wheel. The 2wd boxes the pitman arm points toward the rear bumper and won't work unless you go to crossover steering. If you could post a pic of both your current non power steering box and also your new steering box i'm sure i or someone else could help you much easier.
  6. urbanhunter44
    May 7, 2006
    3
    Sure I'll take a pic today.
    The pitman arm does point towards the driver's wheel, however the part of the pitman arm that connects to the box, doesn't fit the new box. The splines are different.
  7. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Take a pic of the new box, i'll bet it is splined all the way around the sector shaft which is a 2wd box and not a 4wd box.
  8. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    If your pitman arm doesn't have the tapered tie rod hole, it could be a 2wd pitman arm. They usually had the balljoint in the pitman arm, not on the drag link. In which case, you would have a 2wd box or sector shaft also in order to fit that pitman arm.
  9. bp71k5
    bp71k5 3/4 ton status Premium Member
    Mar 31, 2006
    6,238
    284
    San Jose, California
    If you're anywhere near CA, I've got a box and a pitman arm you can have. I went with crossover steering so the old stuff is stored.
