Problem, need help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by loudandproud, Sep 2, 2000.
  1. loudandproud
    loudandproud 1/2 ton status
    Jun 27, 2000
    451
    Ham Lake, Minnesota
    The fan on my engine hits the plastic thing that goes around it. I don't know what it is called but it attaches to the radiator. The fan blade has broken out part of the plastic down on the bottom where it hits. It only hits when my front tires drive over a big bump, I notice it most when one of my tires goes over the bump and the other stays on the ground. So I think something must be loose somewhere, but I haven't got a clue where to look. Any ideas??? Thanks
  2. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    The plastic thingy is your fan shroud. I'd bet that you need new engine mounts, I can't think of anything else right now that would cause your problem.
  3. realsquash
    realsquash 1/2 ton status
    Jul 12, 2000
    778
    SE WI
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Jason and Squash are both right. Dont take your shroud off,need it for cooling. Fix your mounts.
    Get Out and VOTE!
  5. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    To me it seems like you have hardly any clearance around your fan at all. From the attached pic it looks like the fan is damn near touching the shroud. It should have more room than that.
    <font color=purple>L8r,
    .Riz.<font color=purple>
  6. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Well you can get an electric fan and mount it on the back side of your radiator. So it will pull the air thru the cores. This frees up some horse power. The down side is, if you ever cross deepwater your up a creek with the el'cheapo fans. Either way the rotting or toasted body mounts are going to need replacement. Dick Cepek sells a total body kit for your truck. I got a kit from their mail order out of Petersons 4wheeler for $135. These are the garden variety poly kits. They have all the bushings. My buddy got a kit from J.C. Whitney for $104. They were Daystar brand. he hasnt complained about hem yet. Mine are just the same, no complaints. The motor mounts are going to run anywhere from $16 to $30 depending on where you go. I dont know what you want to do. Either way its going to cost some $$$$ and a lot of elbow grease. All of it is worth it. K5s' cant be beat and dang sure cant be kept down.
