Problem solved, thanks all.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ben, Jan 14, 2004.
  1. Ben
    Ben Registered Member
    May 3, 2002
    96
    Pick a country in SE ASIA!
    Someone posted an article about how to hookup your lights to shine brighter. I did a search but only see the 4 headlight system posted. Who has done the single headlight hookup? Thanks!
  2. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Re: I did a search but still no luck...
    The basic theory is the same. The stock wiring is too long and too small. You can modify the 4 light design for 2 lights. Basically larger wire and some relays will do the trick! I just changed the stock lights in my 71 ElCamino to sealed halogens and what a difference!
  3. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    here you go, click HERE. This has both diagrams. I have this one saved in my favorites for when I get around to doing it on mine. /forums/images/graemlins/thumb.gif
    Rick
  4. Ben
    May 3, 2002
    96
    Thank you!
  5. Re: I did a search but still no luck...
    Painless relay at Summit
    Not sure if this will work for your application, but its the same idea.
  6. Ben
    May 3, 2002
    96
    I wish I could find the kit for the single headlight system instead of having to run around all over creation here in Korea looking for the parts I need!
