Problem Solved: Tire dismounting 15" wheels
Discussion in 'The Garage' started by fr8train, Jan 4, 2003.
  1. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Problem Solved: Tire dismounting 15\" wheels
    I've got 38" Denman Ground awgs on 15" steelies. How hard would it be to dismount them myself?
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Re: Tire dismounting 15\" wheels
    The hard part is breaking the beads loose. /forums/images/graemlins/frown.gif A tire machine will make that job WAY easier. I've mounted 35x12.50x15 BFG Muds at home, but taking them off is a lot harder. I found a local place that would do it for $2 each, so I let them have at it! /forums/images/graemlins/cool.gif
  3. fr8train
    Aug 2, 2000
    1,712
    Maryland
    Wish I lived near you. $10 a tire here /forums/images/graemlins/eek.gif. What did you do to break the bead? Can I do this with a crowbar? OR do I need one of those "special" tools"?
  4. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    use a jack and bumper. this will break the bead, the use a crow bar...
    NITRO
  5. fr8train
    Aug 2, 2000
    1,712
    Maryland
    Can you explain this? *holding a candle proudly* My name is Drew, I am an IDIOT. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  6. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Some places here wanted $10 each also. But I just kept calling around and found the place that does it for the $2 that it really should cost. It takes less than 1 minute per tire with a tire machine.
  7. bigjbear
    Feb 18, 2000
    13,966
    448
    Marietta GA
    Lay the tire on the ground under your bumper, put your Hi-Lift's base on the sidewall and start jacking. Before you do this don't forget to remove the core from the valve stem.
  8. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    I was going to poke fun at you but I'll save that for a later date ok?
    If you have a High Lift Jack you can use that to pop the bead How do you ask well you put the tire on the ground and put the Jack on the edge of the rim not on the rim mind you. Then raise the part of the jack that you would put under the bumper and put that under the bumper as you move the jack handle the presser will pop the bead. Do you have a Idea on how this will work now? /forums/images/graemlins/cool.gif
    Eric
  9. fr8train
    Aug 2, 2000
    1,712
    Maryland
    Thanks guys. Yesss excellent, now Simpson. ..... wait a sec. I 'm the joke here /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif Sure HL I'm a good sport. /forums/images/graemlins/grin.gif
  10. fr8train
    Aug 2, 2000
    1,712
    Maryland
    Problem solved guys. Wally World has saved thy arse again. $3.50 per tire for mounting/dismounting. And they dont care how big the tires are /forums/images/graemlins/thumb.gif. If youre in Maryland near Baltimore or Annapolis the Walmart at Arundel Mills has a tire center in it.
  11. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Maybe that's where I should go. I just spent $40 to get two tires mounted and balanced.
  12. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    It pays to shop around! /forums/images/graemlins/thumb.gif
  13. bigjbear
    Feb 18, 2000
    13,966
    448
    Marietta GA
    that is because you live in Пролив оутта ПРК
    I guess I can't copy/paste that and I sure as hell can't type it from my keyboard, but you get the point.
  14. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Yep. The location is the only place on like three boards that it works.
