*Problem solved!!* what color are the park/neutral switch wires?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TruckNutzDude, Nov 3, 2004.
  1. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    <font color="red"> Thanks for all your help guys!!! I installed the gauges and cleaned up my positive terminal and she turned right over. I'm wicked excited!!! </font> /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif
    I need to know what color the wires are coming off the park/neutral safety switch on your steering column. I swapped out the automatic tranny and steering column a few months ago and am finally ready to try and start my rig. Unfortunately I can not get power to the starter and I think these wires are not connected but I don't remember what color they are or what the plug looks like. If you could take a picture of the plug and wires coming off the switch that would be a huge help. I've only got a few more weeks left to get it running before it sits for the winter... again. /forums/images/graemlins/doah.gif
  2. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
  3. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    Re: \'87-\'91 TBI w/ auto trans... what color are the park/neutral switch wires?
    Perfect! Now I just have to go find them in the tangled mess of wiring under what used to be my dash. /forums/images/graemlins/thumb.gif
  4. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    I found that wire and jumped it out... got nothing. I HAD power to the fuel pump but this time there was nothing there either. I checked my fuses and they are all good. I'm thinking my starter may have corroded terminals or I have a bad ground somewhere. Does it matter that my gauges are not in the truck? I took the entire gauge cluster out and it has not been installed yet. /forums/images/graemlins/dunno.gif At this point, ripping out the entire TBI system and running a carb. is starting to look pretty good. /forums/images/graemlins/doah.gif
  5. tunedportk5
    tunedportk5 1/2 ton status
    Jul 13, 2004
    371
    Union City, CA
    Does the computer for the tbi have the VATS program that works with the codes key. that would keep it from turning over
  6. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    I don't know much about the TBI system. It was raining all day yesterday so I didn't get to check out too much of the system or install the gauges. I think I'm going to pull out my starter since I think it might be bad and I'll start checking all my grounds and terminals to see if they are corroded. I may have forgotten to mention that my rig has sat in my driveway for about a year without starting... /forums/images/graemlins/doah.gif My build up has taken a lot longer than I expected. /forums/images/graemlins/angryfire.gif
  7. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    I went out and got a new starter today just to be safe. I have power to the fuel pump again and a new battery. I tried jumping out the wires on the above plug and there is still now power to the starter. I'm going to install the gauge cluster in a few minutes and see if that helps. I'll check back tonight and let you guys know how it worked out. Any other suggestions would be appreciated. Thanks! /forums/images/graemlins/waytogo.gif
