Problem starting, ECM?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rem7600, Sep 15, 2001.
  1. rem7600
    rem7600 1/2 ton status
    Apr 16, 2000
    125
    Coeur d\'Alene, Idaho
    89 w TBI 5.7
    Can an ECM (Electronic Control Module) on the distributor fail
    intermittently or is it typically an ALL or nothing problem?
    I've had 2 instances (over the last month) where the truck
    turns over and over and over and doesn't want to start. I
    can smell fuel so I think it's spark related. Truck normally runs
    great and idles quite smoothly. Other thoughts or things to
    check?
    Any help/suggestions will be welcomed and appreciated!
    REM7600
    <a target="_blank" href=http://www.geocities.com/rem7600/>http://www.geocities.com/rem7600/</a>
    <font color=purple>REM7600 - '89 Jimmy</font color=purple>
  2. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Take out a plug and lay it against the motor while someone cranks it and check if its getting spark. Do this for each one. Also check that your getting 12v to the coil. All the ECM controls is advance.
  3. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    The ECM controls the distributor.If it goes out you will have no spark.You can have it tested at most part stores to see if thats your problem.
    A BIG HAMMER CAN FIX ANYTHING.. [​IMG]
  4. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    replace your fuel pump and you will be fine to go
    4x4k20
  5. rem7600
    Apr 16, 2000
    125
    If it were the fuel pump (and I'm not saying that it's NOT), then why would it be so sporadic? Like I said in the original post, it's only happened 2 times. I would say over the course of a little over a month.
    REM7600
  6. rem7600
    Apr 16, 2000
    125
    Hey BG71,
    I'm assuming you mean the next time I see the problem, YES? Or do you mean right now while it is not experiencing any troubles?
    REM
