problem upgrading from drum to disc
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 70jimmy, Sep 13, 2005.
  1. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,953
    248
    Released from Pueblo, told I belong in Southpark
    I recently got a master cylinder and booster for a 1972 1 ton 4 wheel drive which they say is the same for 3/4 by the part number. My new axles are 4 wheel disc. Anyway I put everything on and noticed that the rod going into the back of the booster was tight agaisnt the firewall. I put pressure on it to get it to mount. When I pushed on the brake pedal it wouldn't move.
    I measured the bracket and it was like 3 and 1/2 inches from firewall to back of booster. So I went to a friends first gen stash and checked his trucks. I found all but one of his had brackets that were more like 5 and 1/2 inches from firewall to back of booster. I put the different bracket on and voila'.
    I also found the truck I took the bracket off had a support rod that went from the upper driver's side bolt on the back of the booster at an angle toward the driver's side firewall and mounted on a stud there. So I stole :o (I mean aquired that also).
    Just more screwed up stuff I ran across in my restomod saga!! :rolleyes:
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Yup,
    My 72 received an upgrade from 1/2ton to 1ton master/booster.
    the push rod was way shorter on the 1ton stuff. Now RyanB swaped just his booster and didn't need a shorter pushrod?? Duno why?
    Oh and I too have the extra support rod :D
  3. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    thats odd..
    I upgraded and there was no factory mount or location for a support rod...
    what am I doing wrong????
    :thinking: ......
  4. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    Well for starters.....your passenger door opens over your tranny.
  5. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    I always thought that didn't look right :thinking:
    back to the drawing board I guess :o
