PROBLEM W/Vent Tube Corp.GM 10Bolt!
Discussion in 'The Garage' started by az88k5, Nov 2, 2004.
  1. az88k5
    az88k5 1/2 ton status
    Oct 14, 2004
    258
    Prescott Valley, AZ
    I have a Corporate GM 10 Bolt front. I noticed that the vent tube fitting was hanging with the hose and was not connected to the front differential. I found out that the vent tube is pressed in the diff. from the Factory. What's the best way to fix this problem. A:retap the diff to fit a new hose fitting? or B:try to press the old vent hose tube back in somehow? /forums/images/graemlins/dunno.gif /forums/images/graemlins/k5.gif
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    Re: PROBLEM Vent Tube in front Corp. GM 10 Bolt!
    they are pressed it and the one on the front is suppose to be bent, the rear is suppose to be straight.
    you can tap then and install a fitting in them if oyu want, but they are pressed from the factory.
  3. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
  4. az88k5
    Oct 14, 2004
    258
    Prescott Valley, AZ
    So how do I press it back in?
