PROBLEM!!! W/Vent Tube Front 10 Bolt!!!
Discussion in 'The Garage' started by az88k5, Nov 3, 2004.
  1. az88k5
    az88k5 1/2 ton status
    Oct 14, 2004
    258
    Prescott Valley, AZ
    I have a Corporate GM 10 Bolt front. I noticed that the vent tube fitting was hanging with the hose and was not connected to the front differential. I found out that the vent tube is pressed in the differential from the Factory. What's the best way to fix this problem. A:retap the diff to fit a new hose fitting? or B:try to press the old vent tube (witch looks good still) back in somehow? /forums/images/graemlins/dunno.gif /forums/images/graemlins/thinking.gif
  2. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    i think someone said they just JB welded it back in place
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Drill it out and tap it to 1/4 NPT. Then get a fitting from the parts store and put a hose on it and be done.
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    /forums/images/graemlins/weld.gif
    Harley
  5. scubahard
    scubahard Registered Member
    Nov 3, 2004
    47
    California
    I would use JB weld to put it back on. You will need to be careful if you drill it out and then tap it because you might get metal shavings down inside your differential. Or you could use this opportunity to change the front diff oil and make more of a permanant job.
  6. az88k5
    Oct 14, 2004
    258
    Prescott Valley, AZ
    I allready pulled the front diff cover so metal shavings won't be a problem. If I tap it. JB weld is also a good idea. Then I can use the old original tube fitting. /forums/images/graemlins/thinking.gif
  7. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I vote for tapping it. Tape/hold a magnet against the hole while you drill/tap and the shavings won't be such an issue.
  8. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    when i did mine i loaded up the tap with grease and it held all the metal shavings, i drained tha fluid later with no metal in it so i guess it worked /forums/images/graemlins/peace.gif
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I wouldn't be worried about a couple shavings from the tapping operation but I'd clean it out anyway.
  10. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    May not have to drill it. A lot of those vent tube holes are close to being the pilot hole size for 1/8NPT Might check that first.
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    1/8 NPT is pretty small (around 1/4")
  12. az88k5
    Oct 14, 2004
    258
    Prescott Valley, AZ
    Isn't NPT pipe fitting threads tapered? I would think that tapered threads wouldn't work very well. G or BSP threaded pipe fittings are straight threads not tapered. Don't you think this would be the way to go if using nomal taps that are stright not tapered.
    I think I might just press and JB weld the original one back in the best I can. /forums/images/graemlins/thinking.gif
  13. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Since you have already pulled the diff cover, get yourself a 1/8" NPT pipe tap and tap the hole for a 1/8" pipe nipple, You don't want to use a straight tap because you want the threads to seal up. A straight tap won't let you do that. Also, 1/8" is PLENTY big for an air vent. The front diffs don't build any pressure, and heat really isn't an issue either. I had the EXACT same thing happen to me a few weeks ago. I tapped the hole with a 1/8" NPT tap (no drilling req'd) threaded in a 1/8" x 1" long pipe nipple, and then clamped a new hose onto it. I used a clear heavy duty tube and looped it to create a kind of catch (kind of like a drain trap for a sink). That way, if anything does manage to get in there, I "should" be able to see it and drain it out before it gets into my diff. It cost me about $3 to fix it that way. Much better than JB Weld IMO.
  14. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The existing hole is the right size (at least it was on my 14ff and D44) to tap with a 1/8NPT tap. I put some grease on the tap to keep most of the shavings from getting into the housing.
