Problem with a 1406 edelbrock carb
Discussion in 'The Garage' started by 84CUCV, Jan 13, 2007.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    not sure of the miles on it. been sitting a while to. Press down on the gas and the carb does not move. So ithink its frozen and been sitting a long while. So how do i fix this? or is it time for a new carb? as always thanks guys
  2. 86dieselburb
    86dieselburb 1/2 ton status
    Oct 20, 2004
    219
    Crestline, CA
    Try spraying some carb cleaner on the butterfly's. If that dont work get some carb cleaner in the gallon can and rebuild it. The Edlebrooks are simple to rebuild.
  3. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    tryed carb cleaner, no luck thanks
  4. diesel4me
    Jul 24, 2003
    17,568
    943
    Massachussetts
    try this...
    I'd dump the entire carb in a pail of diesel fuel,enough to submerge it..let it soak a day or two,then gently try coaxing the throttle open..its probably the accelerator pump frozen in its bore thats causing it to be "seized",or the butterflys themselves..
    You could remove the link to it from the throttle lever and see if it the butterflys open then--if so,its the pump thats "stuck",and you may or may not be able to salvage the carb,depending on how nasty it looks inside..Edelbrocks get all white and fuzzy inside if water gets in them..:crazy:
  5. JohnnyWagon
    JohnnyWagon Newbie
    Jan 11, 2007
    Spokane, Wa.
    Make sure all the external linkage pieces are intact and functioning.
  6. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    yea, i just tried again it pretty solid. thanks guys
  7. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    take it off the motor, break it all the way down til its nothing more than a carb body and rebuild it. Probably just super gummy from sitting for a time period.
  8. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    yeah, looks likr that is waht i am going to do thx
